Old 05-02-2026, 09:13 AM
Mike Davis's Avatar
Default 1980 TA engine harness
Swapping the 301 out of my 80 TA for a 455. Factory engine harness is cobbled together so looking to replace with new harness.
Question for the guys that have swapped engines will the factory harness reach or since I need to replace the harness should I just go with a 1979. 400 harness?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 05-02-2026, 10:08 AM
78w72 78w72 is offline
Will the factory harness reach what? The 301 engine is in the same position and uses the same basic accessories as a 400 or 455, the harness should be the same length as other engines use.
For a new harness, I have use American Auto Wire, AAW, very good quality.
