Old 05-02-2026, 01:04 PM
oldman66gto's Avatar
oldman66gto oldman66gto is offline
Default Windshield Wipers & Washer for 1966 GTO
Question:
Is the "washer" motor and the wiper switch on the same circuit?
If one works, does the other?
And, if fused, where would the washer pump motor fuse be??
Also,does anyone have a schematic or picture, as to the routing of the washer hose from the container to the pump? I know it goes across and under the fan shield on the radiator and across the radiator support. How about from the driver side of radiatior support along the fender to the pump?
Any help is appreciated!
Allan Bishop
Old 05-07-2026, 07:10 PM
Jeff Hamlin's Avatar
Thumbs up
All controlled by the switch.
See wiper Fuse 2nd pic.
The hose is run from the pump up over the inner tub, behind the fender bolt points and then back out across the top of the support.
Not sure how hard core you are but the unique piece of the WW hose is the factory splice used on the DS.
This was due to washer jugs for the 6cly were on the DS and 8cyl on the PS, so the factory just spliced the hose to run further on the V8.
Hope this helps.
Name:	66 WIPER SWITCH.jpg
ID:	669617   Click image for larger version
Name:	FUSE BLOCK 1.jpg
ID:	669618   Click image for larger version
Name:	66 WW HOSE 2.jpg
ID:	669619   Click image for larger version
Name:	66 WW HOSE DETAIL 1.jpg
ID:	669620   Click image for larger version
Name:	66 WW HOSE DETAIL 2.jpg
Old 05-07-2026, 07:13 PM
Site sucs for image upload so here is a better pic of the fuse block.
Old 05-07-2026, 07:16 PM
Here's a pic of the Hose Clip used to hold it to the fender flange.
Name:	66 WW HOSE CLIP 1x.jpg
ID:	669622   Click image for larger version
Name:	66 WW HOSE DETAIL 2A.jpg
Old 05-08-2026, 04:02 PM
Jeff.....Thank you so much for your replies. Very helpful.
Allan Bishop
