Old 05-02-2026, 06:29 PM
blue71ta's Avatar
blue71ta blue71ta is offline
Default '72 or '73 Clock & Gauge Cluster
Looking for a 1972 or 1973 gauge cluster that has the large clock instead of the 8K tach, along with the oil / temp in the center and the 160 mph speedo.
thanks
Old 05-03-2026, 07:10 PM
steve v's Avatar
steve v steve v is offline
I have a rough set out of a '72 Formula if you don't find anything better. I can bring to Norwalk if interested.
ID:	669414   Click image for larger version
ID:	669415   Click image for larger version
Old 05-05-2026, 10:04 AM
blue71ta's Avatar
Steve,
thanks for the reply and pics. That is the setup I'm looking for, but hoping for something in better condition. Will keep these in mind though.
Old 05-05-2026, 12:19 PM
unruhjonny's Avatar
I believe I have a set - I can go check later today if you like.
1970 Formula 400
Old 05-05-2026, 01:29 PM
blue71ta's Avatar
Sure, let me know if you have something.
Old 05-05-2026, 04:52 PM
Talking Possibly in deep Old Stock
Ck'ed in 28qt Rubbermaid tubs the other night, none with the big clock.
Waxed chicken boxes from the 80's are next.
Yes, I have a system.
Old 05-05-2026, 05:01 PM
unruhjonny's Avatar
wowzers!
That's a LOT!!
I have my few gauge clusters in one fruit box.
1970 Formula 400
Old 05-05-2026, 05:21 PM
wowzers!
That's a LOT!!
Funny you should say that Jon, one of my organization obsessions for the last 10 years has been when I've had time in the evenings, cutting down standard sized SAGE brand (white background) Apple boxes to make 3 different heights of stackable parts tubs. Use these up in my dealership shelving.
Many of those cut down SAGE apple boxes are even reinforced inside for heavier small parts. The problem with the 28 qt Rubbermaid tubs, besides being hard to find, is eventually the corners of the lids crack when one stacks them up too high.
Old 05-05-2026, 10:30 PM
Held for Ransom's Avatar
thanks
You should be able to use the early '74 unit also.
So long, farewell.
Old 06-01-2026, 07:06 PM
unruhjonny's Avatar
Did you ever find a set?
Asking because I sent a PM about this several weeks ago, and never heard any sort of reply.
1970 Formula 400
