Old 05-07-2026, 07:35 PM
433lemans's Avatar
433lemans 433lemans is offline
Default 69 Lemans Front Coil Springs Replacement
So I'm finally back to converting my front drums to disc brakes. I'm also installing new coil springs. As pictured, the original springs have the top tapered to give a relatively flat contact surface. The new springs are not. Should I grind the new spring so it is tapered also? Looks like it could wear into the spring pocket if I don't do something.
ID:	669628   Click image for larger version
