Old 05-07-2026, 10:08 PM
sdbob sdbob is offline
Default Again Oil Filters- watching DCI s podcast on Wix filters
I didnt see 2nd part of Wix oil filter podcast.You guys that do a lot if oil changes are Wix and Napa gold still good filters? I'm thinking Baldwin as Tom has said. I m going to change oil in SD I sure dont want a problem. Thanks Bob.
The Following 2 Users Say Thank You to sdbob For This Useful Post:
Old 05-08-2026, 07:02 AM
67Lemons 67Lemons is offline
Napa Gold filters are no longer Wix, they are made by PGI, it’s a good filter but I don’t feel it’s the same quality as the OLD Wix. Wix has changed as well since being purchased by Mann Hummel, doesn’t mean it’s better or worse just different, I’d probably go with Baldwin personally.
1972 GTO
Old 05-20-2026, 01:45 PM
HWYSTR455's Avatar
Refresh my memory on the new Wix filter issues?
Have a link for the Wix filter vid?
Old 05-20-2026, 10:29 PM
70GS455 70GS455 is offline
PGI build quality is better than the old Wix
https://bobistheoilguy.com/forums/fo...oil-filters.6/
Microguard Select is very good, excellent build quality, and easy to obtain.
Old 05-20-2026, 10:48 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The old NAPA gold is about 1/4"-3/8" taller than current WIX.
And shorter than AC Delco -which are no longer available.
The Mobil one is smaller diameter and shorter.
Skip Fix
Old 05-20-2026, 11:15 PM
SRGN SRGN is offline
I just bought a few Baldwin filters for my 62. Surprisingly heavy in weight compared to most. Next oil change I'll put it on.
