Prev Previous Post   Next Post Next
Old 05-09-2026, 08:50 PM
gtorich gtorich is offline
Default McLeod throw out bearing 16505
Did a search, not much coming up, was wondering if anyone is running this in a pontiac. Summit has it for chevy, buick, olds, pont. But when you check on the fit it only comes up for a buick, i called and they said buick only. Seems odd
Thats why i want to check with you guys, I have a center force dual friction clutch and pressure plate but running a prw flywheel, stock fork and stock bellhousing.
According to the instructions from center force after doing all the measuring i need to get an adjustable pivot ball, didnt really want to go this route so i thought this adjustable tob would be the better way to go.
After all the measurements it seems i need to move the pivot ball about 1/8 towards the motor. I tried a pontiac mediium size ball and thats way to big.
Any thoughts on this
Rich
