Old 05-14-2026, 08:01 AM
steve25 steve25 is online now
Default Iron RAIV porting
I am having the good fortune and pleasure of porting for a good friend and drag race pal a iron RAIV head to match one that has been ported already that he came into possession of.
The head that has been ported is an original production one ( the other over the counter) and has been said to have been ported by our great recently departed Pontiac guru Pete McCarthy.
This ported head was set up for a 2.15” 30 degree seat valve and flows very well for its 1.77” to 1.80” throat that was used seeing that these heads can go 1.850” safely as compared to trying that throat size in a iron D port head.
Here are the stock flow numbers and the as received ported flow numbers @28”
I have not CCed an intake port yet, but will do so and post that up before the end of the weekend.
.100”——-84.2——54.2
.200”——-148.1——-148
.300”——-193——209.3
.400”——-213.7——247.4
.450”———————258.2
.500”——-223.7——272.9
.550”———————282.7
.600”——-232——286.2
I will post up some photos and port dimensions later today.
The Following 3 Users Say Thank You to steve25 For This Useful Post:
Old 05-14-2026, 10:24 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Very cool! Nice numbers
Go fast, see Elvis!
Old 05-14-2026, 10:26 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Paul has my SR 614s to look over.
Skip Fix
Old 05-14-2026, 11:48 AM
Cool!
Thats what these heads are, a 614 casting.
Old 05-14-2026, 05:29 PM
Skip Fix's Avatar
Mine were SR castings . Got new never used form a local guy. On outer exhaust port untouched had a small casting hole we had to weld. I think with the NMCA "legal" pocket porting and port match they went around 249 cfm. Exhaust was 85% plus. Why a reverse split cam went the fastest of the 4 cams I tried back then. I knw John Angeles in his SS car and John Schloe in his RAIV stocker both ran single patterns.
Skip Fix
Old 05-14-2026, 07:39 PM
PAUL K's Avatar
I might add your very nice 614 heads
Go fast, see Elvis!
Old 05-14-2026, 07:41 PM
PAUL K's Avatar
Steve what exhaust valve are these heads set up for?
I remember working on a pair that were originally set up by Butch Elkins and they used 2.08/1.81 valves
Go fast, see Elvis!
Old 05-15-2026, 04:38 AM
Paul these are 2.15” 1.77”.
Strange that someone would go with 1.81” exh valves unless you were building a boosted motor and needed a ton of exh flow for a really high ratio.
I have taken D ports up to 240 cfm and can’t see why these 614 exh can’t do 255 to 260 if needed while staying with a 1,77”.
Old 05-15-2026, 04:52 AM
Here’s a few photos and dimensions of the as revived ported intake ports.
The throats range from 1.76” to a tad over 1.77”.
Port height at the flange is 2.390”.
Port width at the bulge averages 1.065”
Port height at the crown of the short turn 2.030”
Port width at the crown 1.485”
The short turn is a 100% complete quadrant of a 1.77” , so it’s layed back a lot!
ID:	670104   Click image for larger version
ID:	670105   Click image for larger version
ID:	670106   Click image for larger version
The Following 2 Users Say Thank You to steve25 For This Useful Post:
Old 05-15-2026, 07:28 AM
Half-Inch Stud's Avatar
I know it takes careful decisions to achieve 1.77" bowl throat. Nice.
Can you measure WxH at the pushrod bulge and compare to the bowl CSA?
Just noticed you posted the measures so i can calc. From the looks you achieved a choke-free Pushrod bulge passage so them irons gonna make power.
I use a very long 3/8 extension in the pushrod hole as a (visual) guide for bulge iron thickness, while belt sanding the insulting iron. Two goals being a straighter shot and choke-free CSA beating application RPM-CID choke calc.
Unshroud the intake valve at the Chamber? unshroud the EXH? Helps to sharpie the head gasket CYL to the head too free-iron excess for unshrouding goals.
No touche the EXH ports or flange right?
...really enjoyed my R-96-A port work: an effort in minimalist porting. Makes the iron of higher value!
Old 05-15-2026, 12:07 PM
Skip Fix's Avatar
I agree on larger exhaust valves in them. I had reversion issues running mufflers for the rules. Exhaust ports flowed almost as good on the flow bench backwards as forwards! Heck even my 6X-4s we added 1.77s to jumped way up in E/I ratio. I found smaller header tubes going from 2" to 1 3/4 and the reverse split cam ran the best. It was pretty non responsive to jet changes before that.
Skip Fix
Old 05-15-2026, 03:36 PM
Dragncar Dragncar is offline
282 cfm at only .550 lift, nice. You could make some good power with that.
Old 05-15-2026, 05:41 PM
Sure could, even with a hydro flat tappet.
Old 05-15-2026, 06:23 PM
Gary H's Avatar
Gary H Gary H is offline
Very Impressive! Thanks for the pictures too.
Old 05-15-2026, 06:41 PM
Welcome!
Old 05-20-2026, 05:31 PM
joes455 joes455 is offline
Port height at crown 2.030 wow and entry 2.390.
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 05-20-2026, 06:22 PM
Yes, in fact I will be CCing that port in like 20 minutes.
I will report back when done.
Old 05-20-2026, 06:54 PM
I think the tallest you can go in a stock 6x is 1.7 or so at the crown
Old 05-20-2026, 07:03 PM
Sounds about right if you don’t make the mistake of laying back the short turn too much.
I can check my notes .
So this RA4 port is checking in at 209.4 CCs, so not too far off from a off the shelf Edelbrock.
Old 05-20-2026, 08:21 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Why is the 100 number effected so much?
