Old 05-15-2026, 02:51 PM
heckinohio's Avatar
heckinohio heckinohio is offline
Default Local '64 GTO with no steering column!!!!!!!!!
Noticed this car on the way home, circled the block to look. Good solid....with 'chubby' engine......not a problem, but no steering column is. That is a bigger problem than the engine.
What other GM columns will fit?? Is there an after-market???
PJH
Old 05-16-2026, 08:19 AM
tempest1964's Avatar
Depends on what you need. Column shift? Floor shift, tilt or non? I believe 64-66 Pontiac A-bodies are interchangeable but not identical. Not a 100% sure on the interchangeable. I would start with eBay. Good luck
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
Old 05-17-2026, 07:24 AM
MarkS57's Avatar
MarkS57 MarkS57 is offline
If a floor shift car, it's easier. Our sponsor offers a rebuilt column for non-column shift cars, but you would have to eat the core charge. I bought one of these, pretty good. They also have brackets etc if needed.
https://www.amesperf.com/parts/35029/
65 Tempest, 400, TH400
86 Fiero SE 2.8
Old 05-18-2026, 07:54 AM
Andre's Avatar
Andre Andre is offline
Im near certain that if you place a want ad on here you can get a floor shift column (64-66 A Body). Folks might even give you a column shift column for free, and with a few hours of handiwork, you can make it appear to be a floor shift column.
