Old 05-20-2026, 07:25 PM
gtorich gtorich is offline
Default Remflex gaskets 12-001 vs 12-004
Remflex 12-001: Features standard oval end ports and D-shaped center ports (typically matching standard factory/OE heads and manifolds).Remflex 12-004: Features larger, D-shaped center ports explicitly designed to accommodate aftermarket headers and high-performance cylinder heads with larger port openings.
Just wondering if i put the wrong gaskets on.............i have the 12-001
I have dougs headers and kre 295cfm heads, oh boy
Any of you guys using these 12-001 on kre heads.
Rich
Old 05-20-2026, 08:19 PM
tom s tom s is offline
The 63SD 980 heads have a wider center hole to hole than ALL other Dport heads.Might have the gasket for them.Tom
Old 05-20-2026, 09:56 PM
Tom S, sorry for the confusion, are you saying the 12-001 would be ok for my kre heads.
Rich
Old 05-20-2026, 10:46 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I can tell you the Remflex 2" for round ports do not have the right bolt spacing for the center two ports.
Skip Fix
Old 05-21-2026, 12:01 AM
Dragncar Dragncar is online now
I have Remflex on my High Ports with no issues.
Old 05-21-2026, 09:49 AM
001 looks like the correct for standard D port heads.Tom
