For the guys who havn't seen this on fb. I dropped a few hundred lbs with fiberglass front end and wilwood brakes. Hooked up good on this launch. Car didn't like a harder hit , left at 3k off the brake.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
| The Following 8 Users Say Thank You to Bill Eveland For This Useful Post: | ||
Thumbs up to ya!
Why no wheely bars?
| The Following User Says Thank You to steve25 For This Useful Post: | ||
That's about as good as it gets
| The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
First time, thats why. Im going to drop the ladder bars down to lower hole and tie the front end down. Wheelie bars are still an option. So this doesn't happen again. I want want to carry a 2ft wheelie out. Just not on the back bumper again.
Holly Crap!
You must be making Big power! |
What are you running for a engine these days ?
517 Ia2, Edl wideport heads
WOW!
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
As a spectator, that's incredible!
I would be clenching everything if I was inside. I assume you are flying blind...how do you actually manage this? |
Well hopefully its going straight , all i could do was stare at the hood scoop and I did peddle the throttle some so didnt come crashing down hard. no major damage but did take it to work and did an alignment on the car, adjusting the ladder bars to get the rear end square. I set it up for a 4 wheel so can see the rear toe in.
Some air is putting it mildly!
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
Glad every thing is ok, no bends or' brakes'. Nice wheel stand.
Travel limiters on the front will help, as well as the ladder bar adjustment. When I did that years ago, it went right after going on the bumper and I had to get out of it so it didn't go into the wall. Cracked the trans case and bent the subframe when it came down.
V1.......Rotate!!
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
The little that I've read ladder bars are simple but you lift high or lose traction. There was an article in an old Car Craft that Larry Tores and Gary Boze talked about advantages and disadvantages of ladder bars and 4 links. Explaining how to design them.
Further what was nice about that article that made understanding links very simple. They used cardboard! The chassis was one piece,very simple cutout, the rear end was another piece, then the links, one ladder bar, one set of unequal length 4 links, and one set of equal length 4 links. Regular pins were used for pivots. This cardboard is one dimensional. You held the chassis in 2 fingers of one hand. Then you took your 2 fingers of your other hand and torqued
the rear end with the different links. For me a person who knew nothing sure made it simple to understand what the and how the links worked affecting the chassis. I made the parts out of very thick sturdy cardboard still have them somewhere. Just my 2 cts |
Saw Bill's Pontiac and the Gassers at Coles County Dragway last Saturday. Good turnout I believe.
Car looked good!
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
Thanks John! Couldn't get it to hook for nothing though. But we still had fun with the Gasser Shootout...
Ladder bars adjusted down to bottom hole, was in the middle and resent pinion angle. Viking DA front shocks on the way...
Wow, glad you made a clean run
Just as long as we don't see you on one of those "Walked away" videos........
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
| The Following User Says Thank You to 77 TRASHCAN For This Useful Post: | ||
