Old 05-24-2026, 01:37 PM
Skippy597's Avatar
Skippy597 Skippy597 is offline
Default FWIW I broke in a flat tappet and it survived
With all the doom and gloom towards flat tappet cams lately, you rarely hear any good news so I thought I'd share something positive.
Recently did a cam swap on my AMC 360 (I know it's not a Pontiac but it still applies) and everything went fine.
Here's what I used:
-NOS Erson cam (tq20 grind)
-New Hylift Johnson lifters that I sent to delta cams to get their oil notch mod (it's a buck a lifter) and it's similar to crower cam saver lifters but the notch doesn't go all the way down to help with oil pressure
-Isky Revlube on cam and lifters
-Lucas 30w Break in oil filled with extra 1.5 qts
-stock springs for break in (they clear with cam specs)
-varying rpm between 2200-2500 every few minutes and a few blips of throttle in between
I was almost positive that with all the horror stories I'd have to pull it and deal with a flat cam but I was pleasantly surprised.
Just thought I would share some good news on the cam front.
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235
The Following 2 Users Say Thank You to Skippy597 For This Useful Post:
Old 05-24-2026, 02:01 PM
steve25 steve25 is offline
I think a good percentage of the failures stem from too much cranking before the engine stays running and not having the extra oil to really keep things well lubed.
Old 05-24-2026, 02:13 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Congratulations.... Good job!
Go fast, see Elvis!
Old 05-24-2026, 02:24 PM
scott70's Avatar
scott70 scott70 is offline
Not all flat tappets that fail do it on break in. Sometimes it takes a little while ,,, I’ve seen it.
The Following 2 Users Say Thank You to scott70 For This Useful Post:
Old 05-24-2026, 02:38 PM
72projectbird's Avatar
I've done a few flat tappets recently, and all have been fine. As with everything, people will only post negative results.
While true that camshaft and lifter quality has fallen, they're not all spontaneously imploding.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 05-24-2026, 04:41 PM
Skippy597's Avatar
Yeah I've learned that actually from reading your posts. I also primed the oil system for a while before installing the distributor. I tried very hard to keep the rotations to a minimum before starting it.
Skippy597's Avatar
Very true, running vr1 20w50 in it now. I'll keep an eye on things.
Old 05-24-2026, 04:42 PM
Skippy597's Avatar
That's why I figured I'd post a out it because you only hear the bad.
Old 05-24-2026, 05:32 PM
64speed's Avatar
64speed 64speed is offline
Mine was easy too
