Tri-Power Tech 57-66 Tri-Power Talk
Old 05-24-2026, 04:05 PM
Dick Boneske's Avatar
Default End Carb Throttle Plate Holes
Beginning in 1964 and through 1966 the end carb throttle plates have a .026" hole through them. I have asked this before, but still am not certain why engineers added this. I have been adding these holes on all Tri-Power end carb throttle plates for many years now.
My theory is that the small amount of airflow actually moves a tiny amount of fas from the end carb float bowls through the venturi cluster. This prevents the fuel in those carbs from developing sticky, varnishy deposits. This would be for drivers who seldom or never open the end carbs. The fuel in those carbs evaporates and leaves deposits in the float bowls.
Another possible reason for the holes may be to allow a very small amount of air flow into the intake manifold, exhausting any vapor and liquid fuel in the area above the throttle plates. If the vapor and liquid gas is not sucked into the intake, the liquid will seep into the intake and may affect hot starting.
Similarly, the gaskets between the throttle bases and the float bowl were modified to vent the area above the throttle plates to improve hot starting. This change was made in about 1963 to all three carbs.
Do any of you have theories on this?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 05-24-2026, 09:45 PM
Rich-Tripower's Avatar
I thought the holes were there to prevent vacuum from pulling the butterflies open in high vacuum situations where the carbs are closed.
Old 05-24-2026, 10:06 PM
carbking's Avatar
carbking carbking is offline
The throttle body gaskets were vented to prevent or at least minimize stalling in city traffic during hot weather.
Jon
Old 05-25-2026, 03:33 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
The very small holes in the red circle?
ID:	670937   Click image for larger version
Old 05-26-2026, 01:19 PM
Yes .026" in diameter.
BONESTOCK GOATS
Old 05-27-2026, 10:30 AM
Jonsie Jonsie is offline
Makes sense the holes would 'vent' the slave carburetors especially if they were rarely used during driving
The Following User Says Thank You to Jonsie For This Useful Post:
Old 05-28-2026, 01:22 PM
That makes sense. The small holes don't interfere with idle, but flow enough air to keep the throttle plates clear of gas. There is sometimes a small amount of fuel that collects on the end carb throttle plates.
Is there enough airflow to suck gas from the venturi cluster to keep fuel in the float bowls from becoming stagnant?
BONESTOCK GOATS
Old 05-31-2026, 09:13 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Maybe I'm wrong but that looks like the wrong gasket.
Old 06-01-2026, 05:32 PM
You are wrong. The vented base gasket was used on all '65 and '66 Tri-Power carbs. The theory was that there may be fuel on top of the throttle plates, causing difficult hot starts.
I use the vented gaskets on all Tri-power restorations I've done since about 1981,
Some look at the gasket and proclaim the venting causes a vacuum leak. But they need to consider that the vents are ON TOP of the throttle plates--no affect on vacuum.
My original post was a question on why the .026" holes were added to the end carb throttle plates.
BONESTOCK GOATS
Old 06-02-2026, 05:07 AM
Kenth's Avatar
Kenth Kenth is offline
I find it very hard to believe that the small .030" holes would draw fuel from the cluster.
If so, how much fuel would the much larger .055"-.081" holes in the throttle body on the center carburetor for cars with automatic transmissions pull?
Isn't it true that the vented gaskets vent excess vapors when the engine is off and that the holes in the throttle body draw in excess vapors left for combustion instead of clogging the throttle blades?
I imagine Pontiac started using sealed gaskets for the outer carburetors when they introduced the small holes in the throttle blades to avoid dirt being drawn into the venturi via the vented gasket.
Conclusion, for end carbs, no holes i blades, vented gasket.
Holes in blades, closed gasket.
Both vented gasket AND holes in blades, dirt in carbs.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
