Old 05-26-2026, 07:38 PM
bobslilgto's Avatar
bobslilgto bobslilgto is offline
Default 67 GTO a/c fender well bracket
Hi all,
I can't find any picture of the exact location of the heater hose bracket on the fender well for an a/c car, can anyone post some for me? TIA.
Old 05-26-2026, 10:11 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
The extra long heater hose on 66-67 factory air condition cars was secured with a metal bracket attached to the RH inner fender skirt.
I recall there is a small dimple in the skirt for the location.
Also this hose and bracket were located in the same place on the 66-67 A.I.R. equipped cars.
ID:	670992   Click image for larger version
ID:	670993   Click image for larger version
ID:	670994   Click image for larger version
Old 05-27-2026, 02:13 PM
bobslilgto's Avatar
Thanks a bunch, I've seen some in your location and thought that was correct. I also seen some in the front and didn't think that was correct. I appreciate the help.
Old 05-28-2026, 08:04 AM
Andre's Avatar
Andre Andre is offline
Bracket is also used on the 1962 Tempest. Ames carries our reproduction which is exact to the original including correct fastener.
Old 05-29-2026, 03:16 PM
bobslilgto's Avatar
Thanks, I have the bracket and bolt/screw. Bracket is the same on a 62 Grand Prix.
Old 06-14-2026, 08:42 PM
Longs's Avatar
Longs Longs is offline
My heater hose bracket is in the same location as the GTO in post #2. Pontiac plant, 335HP A/C car built late June 1967.
Old 06-15-2026, 06:29 AM
rockdoc's Avatar
rockdoc rockdoc is offline
I have an early '67 GTO with factory AC, but my heater hose does not have this bracket. I can see the dimple for the screw, but there's no hole. My heater hose is running a few inches below the dimple, below the AC hard line. Were these not used in early '67 AC cars?
Old 06-16-2026, 02:44 PM
bobslilgto's Avatar
I have a hole towards the back of the fender well and my car is an April build so I used that hole. I think someone removed all the ac at one time because my brackets and POA was different. Thanks for the input.
