Old 05-27-2026, 11:15 AM
AG's Avatar
AG AG is offline
Default 1968 A-body front disc conversion question.
Friends car has power 4 wheel drum that I am converting to front disc. Can I use the stock master or do I need a disc/drum master with a new proportioning valve?
Old 05-27-2026, 11:26 AM
JLMounce JLMounce is offline
The master is likely fine to continue to use, however you definitely want a disc/drum combination valve.
-Jason
1969 Pontiac Firebird
Old 05-27-2026, 11:44 AM
AG's Avatar
AG AG is offline
Thanks!
Old 05-30-2026, 09:02 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
And if there is as Residual pressure Valve in the front it needs to be removed.
Skip Fix
Old 05-30-2026, 10:32 PM
AG's Avatar
AG AG is offline
What might a Residual pressure valve look like?
Old 05-30-2026, 11:25 PM
Shiny Shiny is online now
Look in the master cylinder... factory drum/drum had check valves (item 26) in the outlets. Not sure about power drum but probably the same:
Aftermarket check valves would be inline, could be anywhere. This is a typical example:
Name:	Master Check Valves.jpg
ID:	671141   Click image for larger version
Name:	Residual Pressure Valve.jpg
Old 05-31-2026, 09:10 AM
Cammer-6 Cammer-6 is offline
Ive converted over by pulling the seat out of the front port where line threads in.
You can pull seat by tapping the cone shaped seat insert,thread a bolt in and yank seat
With needle nose pull the rubber check valve,reinsert the seat.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 05-31-2026, 09:23 AM
AG's Avatar
AG AG is offline
Good to know, thanks again.
