Old 05-28-2026, 11:58 AM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
Default Swapping rear main seal on an assembled engine
455 I've had together for a few years finally got to the dyno last week. Had an oil leak at rear driver's corner. Plate sized puddle after 11 pulls. Looked like pan bolts. Now looking more like rear main seal. 2 piece BOP machine shop did when they assembled sort block. They have assembled most of my motors, even using the old Caddy seal with luck before BOP came out.
How bad a deal is it to swap seals with crank in the motor. Loosen caps let it hang down, or pry up a little?
Skip Fix
Old 05-28-2026, 12:03 PM
73ta's Avatar
73ta 73ta is offline
Have you tried the Wagner Dual Adjustable PCV valve? I got rid of a few leaks on my Pontiac that I had never been able to fix before.
The Following User Says Thank You to 73ta For This Useful Post:
Old 05-28-2026, 01:06 PM
Skip Fix's Avatar
No it id have a regular PCV valve in it tapped into main plenum of T2.
Skip Fix
Old 05-28-2026, 01:46 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Do a tilt test before disassembly
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
The Following User Says Thank You to J.C.you For This Useful Post:
Old 05-28-2026, 03:33 PM
Skip Fix's Avatar
Tilt test after pulling the bolts was totally negative. Now definitely positive at mid rear main carp and below pan. But motor was totally on its butt for a few minutes as I readjusted the chains on the lift. So I don't think even a vacuum pump or different PCV will help much
Skip Fix
Old 05-28-2026, 04:17 PM
John Milner's Avatar
John Milner John Milner is online now
I put a Best rope seal in a 421 of mine several years back and did not pull the crank. I took the main caps off and gently pried the crank up high enough to get the leaky seal out. I then worked in the new rope seal. Once I was confident that it was in the groove, I tightened up the main caps to seat the crank and pack the new seal in. From there, I trimmed the ends of the rear main seal very carefully with a razor blade. It has been leak free for around 7 years. It is certainly possible to change one without completely disassembling the engine.
The Following User Says Thank You to John Milner For This Useful Post:
Old 05-28-2026, 06:10 PM
PontiacHO PontiacHO is offline
Used to remove and install rope seals in GM’s glorious front wheel drive engines while engine in car with crank in place. Had a keen threaded tool with handle to pull the top half out. This was a Kentmore kit that also had a “Chinese finger” installer with a thin cable to work over the crank and draw the seal into place. On some that felt loose I’d jamb and pack the loose ends into the block to ensur that half of the rope was tight in the groove and against the crank. Then trim the excess. The bearing cap half I’d pack the rope in tight also and used a big socket to ensure that half was firmly seated and packed into the groove. Leaving slack in the rope to continually pack in place until it was obvious that it had enough to ride firm against the crank. A small smear of RTV where the cap meets the clock and torque it down. And this has to be oiled so the rope won’t burn up on restart…
Old 05-28-2026, 07:12 PM
Skip Fix's Avatar
Talked to Wade at BOP today. He has seen lots of "false positives" with the tilt test. Rear main seals the do no leak when the motor is running but when tilted drip as oil wicks down the crank serrations. So might have to put it on a run stand to be sure,especially since the dyno shop and I felt it looked more like a pan leak on when running.
Skip Fix
Old 05-28-2026, 08:45 PM
mgarblik mgarblik is online now
I would put an evap. smoke machine on it before taking the engine apart. They find the leak almost every time.
The Following 4 Users Say Thank You to mgarblik For This Useful Post:
Old 05-28-2026, 10:02 PM
SRGN SRGN is offline
I've had good luck with replacing them in car without removing the crank. I use the neoprene seals, with anaerobic sealer on the joining sections. I usually offset the halves slightly from even with the main cap/block as well. As stated above, make sure it's actually a problem when the engine is running before jumping in. It sucks fixing something that ain't broke.
Old 05-29-2026, 07:23 AM
scott70's Avatar
scott70 scott70 is offline
Could not having the normal pcv valve and hose hooked to the intake and valley pan cause a rear main leak on the dyno? Say the grommet was in the valley pan but just open to the air?
Old 05-29-2026, 08:57 AM
As long as there is a breather in the valve cover the crankcase will see the same conditions at WOT with or without a PCV valve. I dont think not having a PCV valve would cause a main seal leak.
Old 05-29-2026, 09:19 AM
Skip Fix's Avatar
Normal PCV valve, hooked to a stock type(Butler/Tomahawk) valley and and into intake main plenum.
Skip Fix
Old 05-29-2026, 09:32 AM
Skip Fix's Avatar
Amazon has a bunch of testers Summit has one any suggestions?
Do they work finding water leaks in the cab of a truck?
Skip Fix
Old 05-29-2026, 11:33 AM
I'm in the same boat with the bop two piece hair piece...subscribed and defeated 👀
Old 05-29-2026, 11:51 AM
73ta's Avatar
Normal PCV valve was factory calibrated for stock engine, with stock valve covers/breathers. Wagner allows for non stock calibration. Seems to work for many to cure small leaks, drips. Worked for me!
Old 05-29-2026, 11:52 AM
73ta's Avatar
[QUOTE= I dont think not having a PCV valve would cause a main seal leak.[/QUOTE]
It does for many!
Old 05-29-2026, 12:58 PM
Skip Fix's Avatar
But it is leaking just sitting there also.
Stock valve covers and breather also.
Skip Fix
Old 05-30-2026, 01:18 AM
Tuske427's Avatar
Tuske427 Tuske427 is offline
suggest to wipe the engine clean and then run it again. this way you can spot a fresh oil trail and trace it up to its highest point to find the source of the leak.
Long live the Muscle Car
Instagram @tuske427
1967 Firebird #BVbird
1967 Firebird 400 4 speed project
1969 Verdoro green GTO (daily)
Old 05-30-2026, 10:53 AM
Skip Fix's Avatar
Got a smoke tester ordered be here next week I'll keep you posted.
Skip Fix
