Old 05-31-2026, 09:44 AM
Greg's tractor Greg's tractor is offline
Default Crager wheel back spacing question
Hey guys and lady's , probably been asked a hundred times but I have a 67 gto , looking to find out correct backspacing for crager ss rims15 x 7 front and 15x8 in back with cooper cobra 235/60-15 front and 245/60-15 on back , summit says 4 inch backspacing on all 4 ? Car is all original with drum brakes all 4 , Thanks
Old 05-31-2026, 10:00 AM
tempest1964's Avatar
4.5” on the front and 4.75-5” on the rear should do it fine. Good luck, and post some pix!
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
Old 05-31-2026, 11:13 AM
Thanks , just don't wanna order the wrong ones , thanks for the help
Old 05-31-2026, 01:54 PM
VCho455's Avatar
VCho455 VCho455 is offline
At a bare minimum I would remove the current rear wheels and measure the rear axle width. Unless you are 100% confident that after nearly 60 years the rear end is original to the car and the axles original to the rear end.
Old 05-31-2026, 06:23 PM
The Champ's Avatar
Verifying the BS of the current wheels would be easier and then verify the clearance both inside and outside for clearance between the tire and any obstructions.
If the existing wheels are 7" and have 4.25" BS, and 8" wheel would need 4.75" BS to put the tire in the same spot.
I have the wider rear end in my '64, but have been able to mount 255/60'15's on the rear of my GTO with 15x7's with 4.25" BS with no rubbing (5" BS would have been better). On the front, 15x7's with the same BS with 235/60/15's with no rubbing with drum brakes, but very light rubbing after switching to front discs (4.5" would have been better).
I now run 17'x7's and ordered my stock appearing rims with 4.625" BS and am pleased with the fitment with my 17" tires
Old 05-31-2026, 06:41 PM
indymanjoe's Avatar
Stay away from the unilugs
I am the Thread Killer!
The Following User Says Thank You to indymanjoe For This Useful Post:
Old 05-31-2026, 07:11 PM
More than likely Cragar SS wheels don’t come with enough backspace.
So you end up with a car that looks cool parked but rubs the tires while driving it.
Big problem with a lot of 15” aftermarket wheels for muscle cars. Shallow backspacing like 3-3/4” or 4” and the only way to make them work somewhat is to use undersized tires, which sucks.
Maybe go for some Weld Draglite wheels. Lots of backspace options in different width ranges. Bonus, they’re a bunch lighter than a Cragar SS.
15x5” with 3-1/2” backspace (11 pounds) and 15x8” with 5-1/2” backspace (13 pounds) pictured below.
ID:	671167   Click image for larger version
Old 05-31-2026, 08:59 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
You can get Cragar SS in any backspace you want, they just take longer to get because they have to come from the factory.
The Following User Says Thank You to hobbygto65 For This Useful Post:
Old 06-01-2026, 07:19 PM
The Champ's Avatar
Just looked at Summit for 'stock' sizes:
CRR-61715 is a 15x7" rim with 4.125 BS - this might work with drum brakes or one size smaller tire.
CRR-61C583447 is a 15x8" rim with 4.75" BS which should work fine with a 245/60/15.
This is based on my personal experience with a '64 GTO with the wider (1968) rear end (both a 10 bolt and now a 12 bolt).
