Old 06-03-2026, 05:49 PM
Default Cure for a nagging problem
Maybe this will help someone else. I have had 2 problems with a stock 389 in a 1962 Bonneville for the 3 years that I have owned the car. When the engine is dead cold and hasn't been started in a while it loads up when first started. Also it is hard to start when hot. It cranks over fine but you have to crank it over and clean it out before it will fire. I removed the Edelbrock carb that was on it to cure linkage, fuel line, vacuum line and air cleaner fitment issues. I thought changing it back to an AFB might cure the drivability issues. NO. I made sure the float level was good and the choke vacuum pull off was OK. Later I took the AFB off my 1964 GP. Bonneville carb worked fine on the GP but Bonneville still had same problems. Over the winter I decided that I would try one of the TRI-Powers that I had on the Bonneville. No better. That's 3 4bbls and the 3-2's also another fuel pump with no change. I decided "what do I have to lose"? I ran a return line back to the gas tank. (It already had the correct sending unit). Then added a GF-98 fuel filter with the return fitting. The car has never ran so good. Idle in park went from 750 rpm to 1100! This cured my problem for $30-$40. Maybe it will also improve my gas mileage. Also maybe this will help someone else.
PS There is a guy on ebay with a close out on the GF-98 fuel filters for about $17
The Following 2 Users Say Thank You to Goatracer1 For This Useful Post:
Old 06-03-2026, 08:38 PM
steve25 steve25 is offline
The typical effects of today’s gas and too hot of an intake manifold.
Today’s fuel boils off at 150 degrees.
Do you shut the motor off the carb(s) heat soak, the fuel not only expands and raises the fuel level but slowly floods out the carb.
And this is not to mention the fuel vapor side issue .
Your return line releaves the pressure of hot fuel expansion.
Old 06-03-2026, 11:12 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
A return from where? The float bowl?
Old 06-03-2026, 11:50 PM
Region Warrior's Avatar
Fuel 10% alcohol..
Ruins old style rubber seals.
Look for gasket seal kit resistant ethanol.
Old 06-04-2026, 10:31 AM
Tandyman Tandyman is offline
Thanks for the feedback.Good information.
How does the gf-98 filter work ? Does it somehow manage to return just vapor or does it return fuel like a bypass fuel regulator?
Glenn
Old 06-04-2026, 12:06 PM
I honestly don't know. Maybe someone else will answer. It was used on the early-mid 1960's V8's with AC so i figured I would give it a shot. It worked so well maybe I'll do it on my 1964 GP.
Old 06-04-2026, 12:22 PM
Sirrotica's Avatar
The idea of running a return line back to tank works because the fuel is continually moving in the line and doesn't sit stationary long enough to boil into vapor. Chrysler, as well as AMC, and a few other manufacturers used the fuel filters with a metered return to tank to solve vapor lock problems back in the 60s. Placed as close as possible to the carb the return system keeps cooler fuel constantly circulating avoiding boiling.
Article about what companies make filters with return lines and why they work, along with part numbers and pictures.
https://esgcapitalinc.com/fuel-filter-with-return-line/
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-04-2026, 09:55 PM
Mopar used a return on their carb fuel filters up until they dropped carbs in the late 1980's.
Old 06-04-2026, 10:25 PM
Both my 67 and 68 FBs had a return line from factory fuel pump.
Old 06-04-2026, 10:31 PM
Have 10n line from mallory pump outside tank to pressure regulator before carb with 8n line back into tank.
Everyone said im supid back then.
Can adjust pressure from 0 to who knows how high.
Keep it constant 6.5
Also supplies 150 to 300 shot n20 if need.
Old 06-05-2026, 05:26 AM
3X24SPD 3X24SPD is offline
Default Return
I had the same (hot) re-start problem on my 69 427/435HP Corvette with the 3 Holleys.
After it had been shut off for 15-20 minutes, it would crank & crank until it cleared out all the fuel- and then fire right up with black smoke out the side pipes.
I just lived with it- it didn't bother me much, and I had way too much other stuff going on to worry about it.
Couple years ago I decided to see what was going on.
Figured out that the problem was the accelerator pump well was heat soaking on the middle carb from the close proximity to the manifold- and the increased fuel pressure from temperature was pushing fuel out the acc pump nozzle.
The float bowl would continuously refill the well- and keep doing this until the fuel pressure inside the carb float bowl was reduced sufficiently- emptying the float bowl and flooding the engine.
I fixed it with a custom heat shield under the accelerator pump- but relieving the pressure from the fuel pump to the carb by installing a return on the fuel filter to the tank is a great solution, as you found.
That guy blowing out those fuel filters on ebay for 61-67 Pontiacs is Max Performance (Chris Casperson).
1966 GTO (Red) WARPATH
469CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
455CI TriPower 4-Speed
1965 GTO (Blue) 3X24SPD
464CI TriPower 4-Speed
1963 Tempest (Red) VIOLENT
440CI 2X4 Mag Nash / T400 (for now..)
Old 06-05-2026, 05:40 AM
I have the same setup on my 63 Tempest currently- installed as a temporary main fuel supply- with a radiator support mounted Fuel Cell and a Mallory 140 down low on the frame rail.
Originally built & designed as an auxiliary dedicated fuel supply supporting the NOS Fogger jetted for a 250HP shot- integrated into the cast iron '65 TriPower intake I ran on my blue '65 back in the early 2000 timeframe.
Nothing stupid at all about that RW. It's an ideal setup.
Old 06-05-2026, 08:46 AM
Thanks for the info Sirrotica.
The feedback in that link certainly backs up Goatracer1's findings. I'm definitely going give this setup a try when I put my 69 Firebird back on the street.
Seems like all the people in the link must of had the return line and proper sending unit already existing on their cars because the common comment
was how easy it was to implement.
I guess having the return and sending unit not in use must be pretty common.
Glenn
Old 06-05-2026, 09:40 AM
peters23 peters23 is offline
A phenolic spacer under the carb may also help.
You need to get the correct style for whatever carb you are running.
Old 06-05-2026, 10:08 PM
My car didn't have the return line just an aftermarket sending unit with a capped off return fitting. I bought a 25-foot roll of the copper-nickel tubing for the return line. It wasn't as hard to run the line as I thought it would be.
Old 06-05-2026, 11:42 PM
One observation of these posts- there are some references to pressure on the fuel in the float chamber. I've never seen a carb without a vent to atmosphere from the the float chamber.
I may be missing the point of having a return-to-tank line from between the pump and carb. It sounds to me like a crutch for a failing float system (or too high a pump pressure). ???
Old 06-06-2026, 12:42 AM
The factory air conditioning equipped cars had the vapor return line. Along with that a smaller water pump pulley to speed up the pump for better cooling.
Both helped prevent vapor lock, so the engineers saw the need to prevent vapor lock and made changes which cost money. Money wasn’t spent unless there was a valid need to do so.
Now with today’s fuels whether your car is air conditioned or not there’s a need for the vapor return line more than ever.
Old 06-06-2026, 09:22 AM
Hi Jack,
You are absolutely correct. Thanks for pointing that out.
There is and should be no pressure in the float bowl- it is vented to atmosphere.
My response was poorly worded. Sorry about that.
The accelerator pump obviously requires a one way check valve- refilling from the float bowl- which in my case was the cause of the float bowl emptying- through the accelerator pump discharge nozzle.
The Shield I installed reflected the source of that thermal and its effect on the constraints of the accelerator pump volume.
Old 06-06-2026, 12:39 PM
The bowl vent on later engines (and possibly early ones) was vented inside the closed air filter. Fumes or condensed fumes are cranked into engine when started.
Old 06-06-2026, 12:46 PM
Sirrotica's Avatar
Years ago I figured out a way to find out if the suction side of the fuel system was drawing in air while running. You just put your fingers over the bowl vents on the carb while the car is idling, and it would immediately flood the carb. This doesn't pinpoint where the problem is, but it is a quick tool to find out if all the connections should be scrutinized for suction leakage. I sometimes used this to trouble shoot a fuel starvation problem.
I've found over the years if there is no air intrusion the car will continue to run the same as if the bowl vents were uncovered. It worked well over the years for me.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
