Old 06-10-2026, 03:27 PM
Default Remote tire pressure/temp gauge
Bought one of these little buggers for $69 after seeing a write-up on the HAMB. Unit fits in the ashtray fine. Write up here.
Would not be bad for monitoring trailer tire pressure either. Charges either solar or USB-C.
The Following 4 Users Say Thank You to Scarebird For This Useful Post:
Old 06-10-2026, 03:41 PM
Shiny Shiny is offline
Thanks!
That is inexpensive if it works, have been considering for our camper.
Do you trust the sensors not to cause leaks? If they do, you think you will be able to buy replacements?
Old 06-10-2026, 04:54 PM
I do not know if they leak any more than the Schrader valves.
Old 06-10-2026, 05:20 PM
OG68 OG68 is offline
I have had a set of TST sensors for my travel trailer for over six years. Changed the batteries a few years ago but beyond that, they're fairly accurate (within a pound).
You can monitor a hot bearing or dragging brakes by the increase in tire temperature and you can set an alarm for low or high tire pressures
https://tsttruck.com
Old 06-11-2026, 12:02 AM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
On trailer also for years. Great use.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 06-11-2026, 07:06 AM
Half-Inch Stud's Avatar
Finally, an electronic gizmo that i might like. Where to buy? Model number? Found it. On Amazon.
Being a elec geek for profession, i usually avoid fettering my cars with elec stuff.
Old 06-12-2026, 10:03 AM
chrisp chrisp is offline
Walmart online $20.00 , used mine for 2 years now trouble free, sensors are caps to go on stems
