Old 06-10-2026, 04:26 PM
DA GOAT DA GOAT is offline
Default 455 Intake manifold ideas
Looking for real‑world feedback on Tomahawk vs ’72 H/O aluminum for my street 455
Here’s the combo:
ENGINE
• 455, .030 over
• SD‑ported 6X‑8 heads (264 cfm)
• Cam H1750
• Advertised duration: 280° / 288°
• Duration @ .050: 223° / 231°
• Lift (1.5 rockers): .463” / .485”
• LSA: 110°
• Q‑Jet (800 cfm)
• Doug’s 1‑7/8” headers
DRIVETRAIN
• 200‑4R
• 2400 stall (flashes ~2600–2800)
• 3.23 gear
• 225/60R15 tires
CAR
• 1965 GTO convertible
• Street use: roll‑ons, cruising, some track
QUESTION
Which intake works better with this setup? I plan on staying in low 5000s rpm, so Performer RPM probably not ideal?
Old 06-10-2026, 05:12 PM
steve25 steve25 is online now
If those -8 heads have only had a clean up mill then I would mill those heads .050” to .060” before doing an intake swap.
Old 06-10-2026, 06:15 PM
Half-Inch Stud's Avatar
Dual-Plane.some good choices. Probably in this order:
Factory iron (port matched, means get the grinder out).
Speedmaster ( mild port matching, means get the grinder but not much to do).
Performer RPM. ( probably need grinder to port match ).
72 HO manifold: ( port match, means get the grinder out)
Seems you got to grind for intake runner CSA match.
Old 06-10-2026, 07:19 PM
PAUL K's Avatar
PAUL K PAUL K is offline
The HO will be faster at the track with a good pass
Go fast, see Elvis!
Old 06-10-2026, 07:29 PM
Formulas's Avatar
Formulas Formulas is offline
Not nearly enough camshaft for a single plane... The Tomahawk excels at a higher RPM than that camshaft will go and the camshaft excels where the single plane intake is lazy... In use you would end up with a truncated power band = narrower than usual
........... The More You Follow The Herd The Less You Can Be In The Lead ..........
The Following User Says Thank You to Formulas For This Useful Post:
Old 06-10-2026, 09:08 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
FWIW, my ported #488945 picked up 56HP over a stocker.
The Following 2 Users Say Thank You to 65 Lamnas For This Useful Post:
Old 06-11-2026, 04:23 AM
The OP is not going to pick up 56 hp with only 260 cfm heads under either intake manifold!
The Following 2 Users Say Thank You to steve25 For This Useful Post:
Old 06-11-2026, 05:38 AM
sdbob sdbob is offline
Truman Fields told me with stock intake try a thicker carb gasket and tune it. I cant remember if open or closed though.
The Following User Says Thank You to sdbob For This Useful Post:
Old 06-11-2026, 07:00 AM
Assure Full advance gets to 34* at ~2400 rpm ( no vacuum adv ).
Assure Secondaries open fully with gas pedal. Tune the Q-JET for crisp Accel Pump response, and Sec Air damper action. Then try thinner=richer Sec Rods.
Hmmm, the cam seems 10*-15* shy on the Intake side. Compare to my signature cam sizes ( i can't see em until this posts) for what is too much duration ).
So maybe 1.65:1 on the intakes only? Not a daily driver so Lobe Life not too big a worry.
Old 06-11-2026, 09:13 AM
Some really great comments. Thanks guys. AI brought me down a bad g rabbit hole. I have a torker 1 and Holley 750 double pumper on it now. I do want to put a rebuilt quadrajet 800 cfm quadrajet on it. I’m thinking I may want to experiment with the qjet, adapter, and keep the Torker 1 on it and see how that goes for street driving.
Old 06-11-2026, 09:46 AM
65 Lamnas's Avatar
I've not seen where anyone has indicated he would. Good job of reading comprehension.
Old 06-11-2026, 11:32 AM
So you’re saying there’s a chance a grinder may be in my future lol. I’ve done some on my last Buick GS so that’ll be alright. New to pontiacs so not familiar with speed master… is that a modern RPM? Also, in your order are you saying the iron intake is the best fit? Even with my 2400 stall? Thanks!
The Following User Says Thank You to DA GOAT For This Useful Post:
Old 06-11-2026, 12:11 PM
Singleton Singleton is offline
If that 455HO intake is a new reproduction, keep in mind that the port alignment is probably WAY off. May require extensive grinding to get them anywhere near close.
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
Old 06-11-2026, 12:41 PM
And your reply in post number 6 wasn’t put up with the intention of alluding to that?
Give me and others on this string a break.
Old 06-11-2026, 02:15 PM
Steve C. Steve C. is offline
Regarding your SD‑ported 6X‑8 heads (264 cfm).
Depending the a amount of port work done to them some grinding may be necessary on a "Tomahawk" intake as well.
See posts 18 & 19 here:
https://forums.maxperformanceinc.com...omahawk+intake
Other comments within that thread might be of interest as well.
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 06-11-2026, 04:17 PM
65 Lamnas's Avatar
You already made an assumption and you were incorrect.
I didn’t imply or allude anything, other than I run a ‘72 HO intake, and they have a decent potential.
If you inferred anything else than that, it’s on you.
I’m out.
