OHC-6 TECH Over Head Cam projects, questions and advice.
Old 06-13-2026, 11:25 AM
Cammer-6 Cammer-6 is offline
Default beehive springs
whos used them?
this would be another solution to the interference of retainer and follower
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 06-13-2026, 01:27 PM
Gary when I built the 301 25+ years ago I used Chevy V8 LS Beehive springs. I think I still have the extra ones in a box somewhere. If I remember correctly we had to cut the spring pockets on the 1bbl head to use them.
Old 06-13-2026, 03:32 PM
what were the results?
do you remember the specs on them?
what head was you using?
Old 06-15-2026, 01:42 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
I wanted to run beehives, but did not find a set with the right spring height. I didn't look at cutting the spring pocket. I acquired an assembled head with them on it, but it also has longer valve stems on them so cannot be ran with a stock cam. I forget the measurement of the stem height, so not even sure it can be ran with a re-ground. I don't have numbers on the springs or valves.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 06-15-2026, 06:23 PM
put a lash adjuster and follower on them to see if theres an interference issue
