Old 06-13-2026, 07:49 PM
433lemans's Avatar
433lemans 433lemans is offline
Default Manual Master Cylinder Bleeding 69 GTO/Lemans
Pleading ignorance but could/should/can the master cylinder be bench bled with the hold off valve as pictured or just the master alone? I'm in uncharted territory here as this is part of my front manual drum to disc brake conversion, and my drum brake setup didn't have the holdoff.
Thanks for helping.
Old 06-14-2026, 09:39 PM
433lemans's Avatar
Well, the assembly is mounted in the car. Bled the master per instructions. I guess nobody has dealt with this so I'll wing it.
Old 06-14-2026, 11:01 PM
tempest1964's Avatar
tempest1964 tempest1964 is online now
Wish I could answer your question, but I don’t know. Been viewed 116 times. Hopefully someone can answer this. Good luck.
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
The Following User Says Thank You to tempest1964 For This Useful Post:
Old 06-15-2026, 01:08 PM
VCho455's Avatar
VCho455 VCho455 is offline
I've replaced the master cylinder twice that I can remember in my 69 but I never removed the hold off valve. Just bench bled the new master and then bled the rest of the system. Check the service manual on the bleeding process with the hold off valve.
Old 06-15-2026, 08:14 PM
433lemans's Avatar
I have an old original 69 service manual but didn't find anything about this. Maybe it's just part of the line bleeding process. I'll find out tomorrow when I start bleeding the brakes. Probably going to be an adventure chasing leaks, with all new front disc brakes, lines, master, etc. Thanks.
Old 06-20-2026, 07:02 PM
gtospieg gtospieg is offline
I heard or read somewhere that you're supposed to hold that little black button in while bleeding the brakes for that line(front I think). If I'm wrong, someone please correct me.
Old 06-21-2026, 02:18 PM
AG's Avatar
AG AG is offline
Bench bleed without the hold-off valve then install and bleed system.
Old 06-21-2026, 02:21 PM
433lemans's Avatar
/\ /\ /\ Did it this way yesterday. It worked.
Old 06-21-2026, 04:31 PM
VCho455's Avatar
Congratulations!
Old 07-05-2026, 09:18 PM
433lemans's Avatar
Finally wrapping up my front end overhaul. Most everything torqued, greased, etc. Also replaced the pitman seal in the steering sector. After bleeding the brakes, I'm pretty happy with them. Replaced the original master cylinder with a Leed unit. Took a while to stop the leaks in the new lines but am good to go now. Now the whole front suspension and brakes are "as new", only now with disc brakes! Front end alignment coming up.
ID:	672866   Click image for larger version
ID:	672867   Click image for larger version
The Following User Says Thank You to 433lemans For This Useful Post:
