Old 06-15-2026, 12:53 AM
1950Mercury 1950Mercury is offline
Default Mini starter 66 GTO
I’m in the process off installing ram air manifolds on 66 GTO. Waiting to get them back from ceramic coating now. I am considering putting on a mini starter. Is this a wise idea? And if so which one is recommended and are they needing to be clocked and if so which way. Thanks
Old 06-15-2026, 11:40 AM
tom s tom s is offline
I use the IMI,made in Whittier CA.Not sure how close the clock is when you buy them.EZ to reclock.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 06-15-2026, 12:37 PM
73ta's Avatar
73ta 73ta is offline
IMI from Whitier also. Great starter and great service from them also on refurbishment of my 20+ year old unit to back to brand new.
Old 06-15-2026, 12:50 PM
tooski tooski is offline
I have a couple from RobbMc. Also easily reclocked.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 06-15-2026, 01:42 PM
grivera's Avatar
grivera grivera is offline
I have a Powermaster Mastertorque on my 66 with Doug's headers and it fits great. Once you attempt install on a clock-able starter, will be pretty evident which way you have to rotate it to rotate for best position. https://www.summitracing.com/parts/PWM-9610
Will Rivera
Old 06-15-2026, 02:50 PM
carcrazy carcrazy is offline
RobbMc! Easily clocked.
Old 06-15-2026, 03:20 PM
Default mini starter
How do you folks feel about the powermaster 9510XS?
Old 06-15-2026, 03:57 PM
tempest1964's Avatar
My builder installed the 9510XS on my recent build. It has been flawless so far. It was easy to clock. Long term, I can’t say yet. I do know it only comes with a 1 year warranty from date of purchase. I guess I deferred to my builder on this. He told me it’s all he uses and said they are very reliable. Builders name is Randy Repp. Owns Pontiac Speed Shop in Brownsburg, just outside of Indianapolis. Good luck
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
The Following User Says Thank You to tempest1964 For This Useful Post:
Old 06-15-2026, 11:39 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
I’ve had a couple RobbMc with the pinion support. Great starter and customer support.
Old 06-15-2026, 11:40 PM
Which mini start is usually bolt on and go without shipping?
Old 06-16-2026, 10:06 AM
HWYSTR455's Avatar
I've got Summit mini starters on 2 Pontiac and one Olds engine and they do fine.
With that said, the PowerMaster 9510/9610 starters are roughly the same price.
Nice thing about the PowerMaster starters is that they are basically infinitely clockable. That's a big bonus.
Old 06-16-2026, 11:20 AM
i82much's Avatar
i82much i82much is offline
happy with my powermaster, had good support for them with starter and alternator as well.
Old 06-16-2026, 11:22 AM
Joe-Touring Joe-Touring is offline
Highly recommend a mini starter. The weight savings and ease of installation are huge positives. I had heat soak issues with my factory stater. Cranks fast and easy now.
I went with a Powermaster 9510, no issues. I am a bit skeptical of the infinite clocking setup, not as simple/robust as the fixed holes of other designs, but I repeat, no issues in years of use.
67 LeMans, 326, M20, 3.31 12 Bolt
Old 06-16-2026, 08:44 PM
Default Mini starter probably powermaster
Are folks needing to shim starters less wine cars have manual transmissions?
Old 06-17-2026, 07:09 AM
HWYSTR455's Avatar
I haven't noticed that, and have both auto & manual cars.
The block pad/starter pad/ring gear relationship is where the adjustments (shims) occur, so technically, it's relevant to each one of those items used together where the variables are.
Old 06-17-2026, 12:56 PM
73ta's Avatar
No shims on my manual car with aftermarket flywheel and starter.
Old 06-17-2026, 04:50 PM
Same here
1964 Tempest Custom
421 SD clone
KRE 74cc heads
Old 06-17-2026, 07:27 PM
HWYSTR455's Avatar
Maybe the manual flywheels are more stable and true than the flexplates, or, you just got lucky...
Old 06-17-2026, 11:16 PM
I always say I’d rather be lucky than good. I can work on my good but my luck I’m kinda stuck with.
1964 Tempest Custom
421 SD clone
KRE 74cc heads
Old 06-18-2026, 10:30 PM
jerry455 jerry455 is offline
I have a Proform starter on my 455 in a 1976 Firebird with Tri Y headers and it works great.
