Old 06-17-2026, 03:48 PM
catc's Avatar
catc catc is offline
Default LIne Loc Install 1970 Trans Am
Hey, has anybody installed a frt. brake Line Loc with the original Master cyl, proportioning valve and hold off valve? If so, would you consider posting photos of your install...Thank you
Old 06-19-2026, 12:54 AM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
pretty sure some vid's on youtube to check that out.
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
