Old 06-25-2026, 08:29 PM
gtobird's Avatar
gtobird gtobird is offline
Question Oil pump gasket?
In the past I've used the paper gaskets that come in the Fel Pro gasket sets, or the gasket that comes with the Melling oil pumps. I build an engine about once every 5 to 10 years so it's not like I really have a track record on what is the best approach. Is it better to use any particular paper gasket, a copper gasket or just go with some RTV around the edges of the sealing surface of the pump without a gasket? Thanks
Old Joe
68 Firebird Convertible
68 GTO Clone (Tempest) Wagon
Old 06-25-2026, 08:43 PM
mgarblik mgarblik is offline
The thin paper gaskets are just fine if you have one. If not, a very thin skim of anerobic sealer can be used. Do not use RTV in this application. RTV is not recommended between 2 machined surfaces. It depends on moisture to cure. You end up with an outside bead that can break off and get into things in the engine and the area you actually wanted to seal between the pump and block never cures.
The Following 3 Users Say Thank You to mgarblik For This Useful Post:
Old 06-26-2026, 04:10 PM
Dragncar Dragncar is offline
My last build I made on from some brass .015 shim stock. Did not want to use the paper one. Used it for the template.
Old 06-27-2026, 06:59 AM
Half-Inch Stud's Avatar
The super-thin gasket is my preference. No RTV, no paint or primer.
Old 06-27-2026, 10:22 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I had a slight issues with one of the slightly thicker black paper/fiber ones. On tear down it was starting to flake off around the pump base like the pump edges were cutting it.
Skip Fix
Old 06-27-2026, 01:56 PM
steve25 steve25 is offline
I have made them out of foil type baking pans with a pair of scissors and and the
needed size gasket punch.
Even if you do not have a punch set a Xacto knife works and in 5 minutes and you’re done!
