OHC-6 TECH Over Head Cam projects, questions and advice.
Old 06-27-2026, 05:12 PM
scotty54's Avatar
scotty54 scotty54 is offline
Default Oil Cap
I have a chrome push-on breather cap but the diameter interferes with the fuel pressure and oil pressure gauges that sit just above the oil fill tube.
Does anyone know the diameter of the correct cap, linked below? Hoping it might be a little smaller.
https://www.amesperf.com/parts/36516/
1968 Pontiac Firebird Sprint
1991 Pontiac Firebird Formula LS2/6-speed
1977 Jeep Cherokee 401/TH400/Quadratrac
Old 06-27-2026, 05:50 PM
Jeff Hamlin's Avatar
The Closed PCV system uses the "Top-Hat" style cap.
like the one in your link.
The Open system, Vented cap is larger.
Depending on how the gauges are set up you'll either have to modify them or use a removeable plug of sorts in the tube.
Name:	OIL FILL TUBE CLOSED PCV (7).jpg
ID:	672545   Click image for larger version
Name:	OIL FILL TUBE CLOSED PCV (8).jpg
ID:	672546   Click image for larger version
Name:	OIL FILL TUBE OPEN PCV (5).jpg
ID:	672547   Click image for larger version
Name:	OIL FILL TUBE OPEN PCV (6).jpg
Old 06-27-2026, 07:26 PM
scotty54's Avatar
Jeff-
I was a little confused because Ames calls the "top hat" a breather cap, which it really isn't if it is used in a closed system.
Ames also has this one (link below) but calls it a "twist-on." Looks like a "push on" to me, and like your photo. It does look smaller than mine. Can you measure the diameter of yours? This one might work.
https://www.amesperf.com/parts/1301/
Old 06-28-2026, 06:59 AM
The "Twist" type are for the V8 Valve covers and have ears to twist and lock.
You want the Push In.
I use the '64 offering and they are close to OE,
I just blast them and repaint with High Heat Black.
If your Cammer is a CLOSED system you don't want the Larger Breather style.
Name:	OIL FILL TUBE CLOSED PCV (5).jpg
ID:	672572   Click image for larger version
Name:	OIL FILL TUBE OPEN PCV (3).jpg
ID:	672573   Click image for larger version
ID:	672574   Click image for larger version
Name:	OIL BREATHER CAP XX.jpg
ID:	672575   Click image for larger version
Name:	OIL BREATHER CAP X.jpg
Old 06-28-2026, 08:25 AM
Cammer-6 Cammer-6 is offline
68-9 used the closed system only
66-7 Calif A.I.R. used closed system
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 07-03-2026, 03:49 PM
scotty54's Avatar
Jeff - the 64 cap from Ames works great. It looks tight but there is enough space to remove and reinstall. Thanks for the tip!
The Following User Says Thank You to scotty54 For This Useful Post:
Old 07-03-2026, 04:48 PM
Im trying to figure out the need for 2 regulators
what pressures are they set at?
Old 07-03-2026, 08:04 PM
scotty54's Avatar
The fuel pressure regulator is set to 3.5 psi, the other regulator is for the oil line to the rear of the head, set at 6 psi.
Old 07-03-2026, 08:17 PM
I didnt think about one for fuel pressure.
You have no problems with valvetrain at only 6psi?
Ive never gone that low.
Old 07-04-2026, 09:20 AM
scotty54's Avatar
The Weber DCOE works best at 3-4 PSI. This I learned from TR6 owners, the best resource so far for learning how to tune the carbs. Other than a rough idle (which I am troubleshooting with their help) the carbs are working nicely.
I must have gathered somewhere that 6 PSI was a good setting for the oil pressure. What should it be? Still learning . . .
Old 07-10-2026, 07:24 PM
scotty54's Avatar
It appears that my oil pressure regulator is a standard Holley which has a range of 4.5 to 9 psi. I now have it maxxed out at 9 psi.
