I noticed on a video I saw that there was a plate installed over the crank sprocket. I'm not sure I have seen it anywhere else. Is this part required on my 455 build?
thats an oil slinger, I believe the factory stopped using them on or around 1967, im sure someone can correct me. But it is unneccessary, you dont need it. a 455 should not have one.
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
| The Following User Says Thank You to mysticmissle For This Useful Post: | ||
What the hell video are you watching!
That’s not a Pontiac V8 ! That motor has a distributor drive gear on the end of that Camshaft! I bet you where mistakenly looking at a video for a Buick 455, not a Pontiac 455.
That's good to know because I don't have one. Thanks
It probably was a Buick. I specifically searched for a Pontiac 455 when I was looking. I thought it didn't look right and that's why I asked.
What are you in need of going, degreeing your Cam, or just seeing how the timing marks on the two gears should be aligned?
I've already done that. I am putting the timing cover on and just making sure I didn't miss anything.
What people usually miss / and or loose because there small are the hollow dowels that sleeve the two lower timing cover bolt holes and center the bottom of the timing cover on the crank..
Hmm I had to look twice. All the Pontiac V8 s I've torn down since 1967 I've never seen that slinger. 55 287, 60 389,61 62 389,65 421,67 428,69 400, 73 -4 SD455,76 79 400s. As was said another make,Buick.
| The Following User Says Thank You to sdbob For This Useful Post: | ||
ford big blocks used them too. never seen one on a Pontiac.
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
