Old 07-04-2026, 08:00 PM
1950Mercury 1950Mercury is offline
Default 66 GTO upper A arm removal
I want to install offset upper control arm shafts on my GTO. It appears that they area not going to be coming out with the engine in the car without getting the bolts out. Has anyone got a remedy for removing these upper control arms with engine in the car?
Old 07-04-2026, 08:46 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
Remove the 4 UCA bolts by using a piece of wood and a long pry bar.
During reassembly, use new bolts.
Old 07-05-2026, 09:17 PM
Has anyone had any luck using a ball joint press or C clamp to remove the upper control arm bolts with engine in the car?
Old 07-10-2026, 08:58 AM
GoGoat GoGoat is offline
I used fillers/spacers against the exhaust manifolds, wood and metal plates tight against head of bolt. Then used nut to push bolt out. be careful installing new bolts back in making sure splines are started straight. Good luck.
66 GTO Conv Tripower 4 spd stock
67 GTO HDTP 400 auto stock
70 Judge 400 RAIII 4 sd stock original
69 Firebird 468 auto 28 option
49 F1 302 aod
