Are they the same?
66 GTO Conv Tripower 4 spd stock 67 GTO HDTP 400 auto stock 70 Judge 400 RAIII 4 sd stock original 69 Firebird 468 auto 28 option 49 F1 302 aod |
I'm referring to the rearend housings. Sorry. Thanks
Yes that are as far as bolting in the rear track width is 60”, but in both years and even up thru 1969 there carrier’s
will only accept certain gear ratios as in. 2.56 to 2.78. 2.93 to 3.23. 3.36 to 4.33. In 68 all the manual transmission cars got the HD 4 pinion Posi with 3.36 to 4.33 gears ( if the car did not have AC )and even the 6 cylinder cars with a manual trans supposedly got the HD 4 pinion rear also . Naturally auto trans cars could have had the HD on special order. In mid 69 the ring gear bolts changed from 3/8” to 7/16”.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 07-05-2026 at 12:34 PM. |
Actually 69 is closer to 68 than 67 is.
68-9 used multi leaf springs,staggered shocks 67 used mono leaf 67 also used radius rods(like traction bars) 69 had flat spots on tubes for jounce bushings internals were same as the GTO/LeMans/Tempest
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
| The Following User Says Thank You to Cammer-6 For This Useful Post: | ||
