Old 07-06-2026, 08:53 PM
SRGN SRGN is offline
Default Post up your aftermarket AC install
I'm looking for better ideas for the aftermarket AC install in my 62. The underdash evaporator assembly is big, and just doesn't look "right", although period correct for dealer installed AC. . I'm probably going to use it for now, but I'm hoping there's another option that is a little more hidden. Everything under the hood is set as far as compressor and condenser. There's no parts cars or junkyard stuff anywhere near me, I've been looking for a while. Only thing I found was a non AC car that was pretty much stripped already. Post up your install, at a minimum it might give me some ideas. I've seen some references to using a system made for a Chevy full size, but not much detail as to how much work was needed to get it done. Any ideas appreciated.
Old 07-07-2026, 09:59 AM
pfilean's Avatar
pfilean pfilean is offline
search for posts VinAir in 61 Pt1 and Pt2 as one way
The Following User Says Thank You to pfilean For This Useful Post:
Old 07-07-2026, 12:16 PM
I had seen those threads, the search function here leaves a lot to be desired. I actually came across the threads on a Google search. I am trying to keep the install more analog, I've had issues with the Vintage Air controller on other builds. Hard to believe that the aftermarket has left us with such few options if it's not an A ir F Body GM vehicle. I've always been a BOP guy, so I'm no stranger to the lack of support for our cars, but I figured they would have had more offerings by now.
For anyone else looking, here's the link to the threads referenced above.
https://forums.maxperformanceinc.com...uXe1nxYY4YXjEA
Old 07-07-2026, 04:37 PM
Can you show a pic of the underdash unit?
It may still be your best bet.
Old 07-07-2026, 05:00 PM
Here it is, mocked up under the dash.
ID:	672967   Click image for larger version
Old 07-07-2026, 05:04 PM
It's back as far as it can be without removing the heater duxt.
Old 07-07-2026, 09:32 PM
OG68 OG68 is offline
I installed a MK IV replica from Vintage Air in my 68 GTO. I used a Pro6Ten compressor from our sponsor since it's a direct replacement for the Delco compressor and uses the factory mounting brackets.
It's tight under the dash but fits well otherwise. The hardest part (mentally, not physically) was drilling the holes for the refrigerant lines below the heater housing and a single hole in the transmission tunnel for the condensate drain
ID:	672976   Click image for larger version
ID:	672977   Click image for larger version
ID:	672978   Click image for larger version
Old 07-07-2026, 10:00 PM
How deep is that underdash unit? That's tucked nicely, as you can see in my pics above the one I have sticks out like a sore thumb.
Old 07-07-2026, 10:09 PM
I have the compressor and lines figured out, I'm going to use a bulkhead fitting so I can put everything where it looks "right". I switched to an 8 bolt timing cover from the 4 bolt, moved PS and alternator to driver's side already. Basically used a 64 GTO configuration, using brackets and pulleys for that application. As an added bonus, the car runs much cooler now and I actually had to up the thermostat to a 180 so it got to operating temperature. Used the 10si alternator that the previous owner had installed to replace the generator. I have a 12si one wire ready for when I ever feel the need to upgrade. If anyone needs it, I have a list of the parts needed to make the changeover.
ID:	672980   Click image for larger version
Old 07-08-2026, 01:44 PM
From the Vintage Air website
https://store-xovjmui41g.mybigcommer...672001-VHY.pdf
ID:	673032   Click image for larger version
ID:	673033   Click image for larger version
