Old 07-08-2026, 11:14 AM
67drake's Avatar
67drake 67drake is offline
Default ‘55 2 Jet carburetor or parts
The top of my Rochester 2Jet has been broken off since I bought this car a while back. As I see it I’m going to have to replace the airhorn, the whole carb, or try some Marine Tex to try to “glue this back together.
Carb runs fine, so would like to replace the airhorn. No luck finding any donors. Anybody have one, or ideas?
I’m afraid the original air cleaner is going to end up bouncing around the engine compartment one of these days after hitting a bump! It’s just resting on the carb currently.
‘55 Catalina
Old 07-08-2026, 05:04 PM
Mr. G Mr. G is offline
Maybe try Steve Barcak at Pontiac Heaven in Arizona. Or maybe E-Bay.
The Following User Says Thank You to Mr. G For This Useful Post:
Old 07-08-2026, 05:39 PM
Contact PY member Dick Boneske.
He’s a Tri-Power restoration expert and may have the carburetor parts you need or can either fix your airhorn or advise how to do it.
Old 07-08-2026, 06:19 PM
694.1 694.1 is offline
You sure it's not a Carter in '55? I have Carter parts.
Still have my 1st Firebird
7th Firebird
57 Starchief
The Following User Says Thank You to 694.1 For This Useful Post:
Old 07-08-2026, 06:28 PM
67drake's Avatar
It’s a Rochester. No idea if it’s original though.
‘55 Catalina
Old 07-09-2026, 03:06 AM
Kenth's Avatar
Kenth Kenth is offline
A kit like this will save the carb:
Name:	air horn repair.png
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 07-09-2026, 02:09 PM
ROCKETMAN269V's Avatar
ROCKETMAN269V ROCKETMAN269V is offline
Default 2GC Airhorn
I may have a carburetor or air horn. Is there a # stamped on the passenger side of the float bowl? Thanks, Bob.
Old 07-09-2026, 02:28 PM
67drake's Avatar
Nothing on passenger side. This is drivers side though.
There’s a similar machined pad on passenger side, but it’s blank.
ID:	673072   Click image for larger version
‘55 Catalina
Old 07-09-2026, 02:31 PM
67drake's Avatar
I’ve seen those! Keeping it in mind for if all else fails
Thanks! I’ll send a PM.
Couldn’t find anything matching on EBay.
Didn’t even think of Steve.
‘55 Catalina
Old 07-09-2026, 02:38 PM
67drake's Avatar
Another thing is, that I didn’t even mention, is one of the screw threads from airhorn to float bowl, has stripped threads in float bowl. It is also the one that holds the manual choke bracket to the airhorn. So choke is non functional till that’s fixed. The bracket just pivots.
So if I can find a complete matching carb to rebuild, would save me from heli-coiling this one.
But I’d settle for just an airhorn.
‘55 Catalina
Old 07-11-2026, 01:59 PM
That's a casting #; possibly an older carburetor that used an aluminum tag for id. If you feel like pulling the carburetor and measuring the throttle bores, along with some additional pics, I have a bunch of old carbs. I recently helped Dick
Boneske out with an airhorn he needed. Thanks, Bob.
The Following User Says Thank You to ROCKETMAN269V For This Useful Post:
