Old 07-09-2026, 11:40 AM
455PWR 455PWR is offline
Default Correct Radiator and radiator tag id
Hi,
I bought a driver condition 76 Trans Am 455 4 speed, no ac 50th anniversary car last fall. Car has 45k miles, but the radiator in the car started leaking and is beyond repair.
Radiator shop has a radiator from a 76 trans am with the following that they could restore for me...
stamped CV on the passenger side tank (manual)
ID tag has:
IF.... FA (FA are large letters)
CV
156
I can't find my build sheet, looked under the dash, in the doors, or in/under any of the seats. I didn't check behind the rear interior panels yet.
From old parts manuals and looking at other 455 4 speed and 400/455 50th car build sheets, most seem to have FA, FC, or FO.
Should it be part number 3030189, 3030111, 3033156?
Some tags have the entire part number on them, this one has 156. Is that the part number or mean it was manufactured on the 156th day of the year (June 5, 1976). My car was manufactured July 1976 per phs sheet.
Would the FA radiator be an accurate radiator to purchase and restore for my car?
1976 Trans Am 455 4 Speed Y82
2002 Trans Am WS6 6 Speed (1k miles)
2009 Pontiac G8 GT SBM
Old 07-09-2026, 05:49 PM
Held for Ransom's Avatar
If the tanks are good on the OE, why can't they recore it?
The tag will have a number on the bottom with the last number being the year indicator. If the one you're looking at is originally from a '73-4, I would be interested in it.
So long, farewell.
Old 07-09-2026, 06:36 PM
The radiator mine has was repaired once and I'm not convinced it is right for the car, though the owner of it since 1977 said it is original. It's tag is not very legible due to pitting.
The picture attached is the one I am looking at. Is the year the last digit of the three larger numbers or the stamping at th base of the clip?
What is the significance of the three numbers? AI says it is the day the unit was made, so 156 = June 5th, 1976. I'm not sure that is accurate.
Old 07-09-2026, 08:34 PM
AI is incorrect.
FA - pick code for assembly line worker printed on the build sheet
IF - tank code on driver side
CV - tank code on passenger side
156 - core code
In between the C and V is the month and year ID.
In the picture of my '74 radiator is G (July) 3 (1973). And part number is on the top instead of the bottom (3030109, can't see the year ID).
Your picture shows A (January), can't read year.
So long, farewell.
Old 07-09-2026, 09:03 PM
Appreciate the info, I don't know much about radiator numbers. Regarding the FA being a pick code, the 76 service manual lists codes for various cars and then corresponding part numbers.
It is hard to interpret, but looks like a 455 4 speed 76 car would have a FC or FA, the FA would be part number 3030189 (the one pictured shows a 30---89 (cant read the numbers in between).
Could this be an accurate radiator for a 76 455 4 speed no ac car?
Name:	Screenshot_20260709_070015_All Document Reader.jpg
