73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 07-10-2026, 11:33 AM
Flashflood Flashflood is offline
Send a message via AIM to Flashflood Send a message via MSN to Flashflood Send a message via Yahoo to Flashflood
Default Horrible screeching noise coming from power steering pump while turning.
77 pontiac lemans with the 403. Just started it up after wiring it. And the power steering pump is making a horrible screeching noise everytime i turn the wheel. It sounds terrible. I've had brand new front tie rod ends shocks and sway bar. Ive also had my bearings are new. I can't understand what would causing this horrible sound. Fluid is also completely full looks a little brown but not terrible,
Old 07-10-2026, 12:09 PM
SRGN SRGN is offline
How does the belt look? Grab the fan and wiggle it to make sure a bearing in the water pump isn't on its way out as well, could affect belt tension or create extra drag on the belt drive if it's failing.
