Old 07-12-2026, 08:47 PM
7t4mula's Avatar
7t4mula 7t4mula is offline
Question Fixing broken Muncie shifter fork stud?
I was so happy to have finally landed a really nice Hurst comp + 4spd shifter that fit great, then I went and snapped off the 3-4 fork stud on the side cover!
I should’ve know it was delicate, only 5/16-18 stud, where the other two are 3/8-24… had anyone tried to pull a side cover off in their 2nd gen while still in vehicle? Seems like it may be possible, maybe drop the tail some for extra room?
I hate to have to pull exhaust, driveshaft & trans if not needed! Please advise if you have any thoughts…
ID:	673248   Click image for larger version
Old 07-13-2026, 07:56 AM
Poncho Dave Poncho Dave is offline
Perhaps you can unbolt trans and turn it for more access
The Following User Says Thank You to Poncho Dave For This Useful Post:
Old 07-13-2026, 01:52 PM
unruhjonny's Avatar
my gut says you should be able to remove the side cover with it installed.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 07-13-2026, 02:33 PM
Carl S Carl S is offline
Using a pair of pliers or crescent, put it in 2nd gear. Then remove the side cover and it just pops out the back. It's very simple to change.
1966 Strato Chief 427 4 Speed 45,000 miles
1966 Grande Parisienne 396 4 Speed Factory Air (1 of 23)
The Following User Says Thank You to Carl S For This Useful Post:
Old 07-16-2026, 02:25 PM
7t4mula's Avatar
Thanks guys, very helpful tips! I rotated clockwise 1st to drain trans fluid, the counter-clockwise to access cover. Shifted to 2nd and cover easily pulled free!
Off to my trans guy for replacement cover with updated bolts and seals, just $100! Feel very fortunate!
ID:	673518   Click image for larger version
The Following User Says Thank You to 7t4mula For This Useful Post:
Old 07-16-2026, 02:27 PM
7t4mula's Avatar
I should’ve mentioned, you can see you have to jack the tail end of the bell housing up to take the load off the transmission crossmember.
I then slid out the rubber adapter between trans and crossmember to give it enough room to pivot.
