Old 07-17-2026, 11:19 AM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default Lead Vs Putty
I have always used 80/20 Lead on seams for QP to roof and QP to filler panel on verts and other cars that have lead from the factory. Never had an issue with this method. Have had plenty of issues with the others. Only cars I use bondo there are vinyl top cars.
What say everyone.
Has someone found a better product that will not crack at these stress joints?
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
Old 07-17-2026, 12:17 PM
Cammer-6 Cammer-6 is offline
Like you I use Lead
My trick is an angle grinder and cup brush.
Contain the lead dust and use PPE.
The cup brush will remove all lead except the final film needed to "tin".
Using the wire brush melts the lead vs a grinder making fine dust
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 07-17-2026, 01:06 PM
SRGN SRGN is offline
Lead has been the longest lasting. A little bit of plastic as the final layer saves time, and is thin enough to last quite a while.
The Following User Says Thank You to SRGN For This Useful Post:
Old 07-17-2026, 03:28 PM
seal between any filler and the lead
and rinse rinse rinse the lead
Old 07-17-2026, 05:37 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
I think most people are afraid of lead along with the extra time it takes and lead bars and materials are a lot more expensive than a can of polyester filler. I've been using lead on roof seams and the rest of the body for 57 years. Lead files easily by hand. I've never used power tools to take it down. Never had it crack. Nowadays I coat the lead with epoxy and block sand over it, seldom needs any putty.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
The Following User Says Thank You to HoovDaddy For This Useful Post:
Old 07-17-2026, 11:57 PM
Yeah I found that out the hard way when I was young and learning. I'm no longer young, but still learning. I epoxy prime every substrate before I put plastic on these days, with the exception of daily driver junk.
