Old 07-18-2026, 09:43 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Radiator plugs for leak testing?
Are there rubber plugs to cover the inlet/outlet to test for core/tank leaks?
Skip Fix
Old 07-18-2026, 11:21 AM
Region Warrior's Avatar
Try local commercial ac electrical ac plumbing supplier.
Old 07-18-2026, 11:28 AM
Are there any radiator repair shops near you?
They'll should have them.
Only one or two shops left here long lake Michigan from I'll to Michigan city steel mills.
Used be 5-6 in both countries.
Old 07-18-2026, 03:30 PM
SRGN SRGN is offline
I've used 2 radiator hoses with a coupler connecting them in the past.
Old 07-18-2026, 07:49 PM
Skip Fix's Avatar
Probably the easiest to chase up!
Did find these
https://www.pegasusautoracing.com/pr...RoC7d4QAvD_BwE
Skip Fix
Old 07-18-2026, 08:37 PM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
Skip, formerly I've used a piece of old inner tube with a hose clamp over the neck, when you're poor, you find stuff lying around the garage to use.................
I still have inner tube and hose clamps lying around my garage, probably still plug it that way today.............LOL
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 07-19-2026, 10:14 AM
Skip Fix's Avatar
That would be an easy way!
Skip Fix
