I meant to post this info a good while ago and I just got my iPad going again to get at these photos off it.
The early Edelbrock chambers have a major machining issue in that when the corners of the chambers get machined by two different cutters they, number 1 leave a bad recessed area ( fuel collection pocket) and 2) leave very sharp edges that make for local hot spots. These two recessed areas collect fuel that does not light off when the spark lights off the main pocket of air and fuel mixture in the chamber. These two pockets of unburned fuel either get sent out the exh as wasted fuel, or worse yet (when the temperature gets hot enough to do such ) finally light off late in the burn of the main pocket and then these two colliding flame fronts create a power loss and destruction as in detonation. In my seperate photos of the stock chamber in these two locations you will see that these two Pockets I have colored up in black marker . You can also see the sharp machining edges left also. There is a particularly bad lip left on the corner of the intake valve that stands up close to .050” and very close to the edge of the valve There are other restriction and sharp edges around both valves on the shallow side of the chamber that I will make a separate post about. Mean while grinding and then polishing out these areas on the plug side of the chamber takes the use of some special cutters and a good portion of the material removal and polishing can only be done with the nose of a lot of tapered sanding rolls, and of course with sacrificial valves in place . Although even then a few areas that needed rework of both valves I found I could only get these areas done without having the protective valves in place, and all of this highly tedious work took me near 3 hours to get the 8 chambers done. One of my photos shows the ruff cutting with no blending polish done yet. I hope these photos work well with my info above here, but for certain these two dimensional photos do not show the severity of these two fuel collection pockets left as Edelbrock shipped these stock.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 07-19-2026 at 02:23 PM. |
| The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Yes, although I don’t recall the 72 Chambers being quite as bad as this larger CC one .
Wow. Kinda surprised they even shipped those, much less someone accepted them.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
The early 87cc chambers were a mess. Once fixed they worked
Great information. I had no idea. Thanks!
1964 Tempest Custom 421 SD clone KRE 74cc heads KRE 230°/236° hydraulic roller cam Rebuilt 3.23 rear end |
