Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 11
1
2
3
Last
Showing results 1 to 25 of 258
Search took
0.07
seconds.
Search:
Posts Made By:
lust4speed
Forum:
Pontiac - Street
04-25-2024, 01:43 PM
58
e head questions alot of questions
2,271
Posted By
lust4speed
I went through the stud selection years ago when...
I went through the stud selection years ago when I went with the AllPontiac aluminum block and first gen Edelbrock RPM heads. A joint effort involving Frank and myself finally got things sorted out...
Forum:
Pontiac - Race
04-18-2024, 03:42 AM
4
Sean Murphy Induction closing down
629
Posted By
lust4speed
SMI carburetors posted on Facebook April 15th that they were closing. Hate to loose another good carb shop.
https://www.facebook.com/people/SMI-Performance-Carburetion/100062920436731/
Forum:
Pontiac - Street
04-13-2024, 02:27 AM
35
High Torque Starters
1,491
Posted By
lust4speed
IMI Tops in customer service also.
IMI
Forum:
Pontiac - Street
04-05-2024, 02:53 AM
26
Still looking for an OF or Stump Puller cam but stumped on that one...
1,511
Posted By
lust4speed
The Stump Puller comes in at 230/236 and the Old...
The Stump Puller comes in at 230/236 and the Old Faithful comes in one step higher at 236/242. While both are usually on a 112° LSA, there is enough difference that operating and performance goals...
Forum:
66-67 GTO Tempest & LeMans TECH
04-01-2024, 02:19 AM
22
Dome light
1,412
Posted By
lust4speed
If the problem comes back I've had two '67 GTO's...
If the problem comes back I've had two '67 GTO's that if the dome light screws were tightened too much it pushed the lightbulb contacts into the roof cross brace and grounded out turning the interior...
Forum:
Pontiac - Street
04-01-2024, 01:22 AM
8
Another hybrid setup
526
Posted By
lust4speed
To me lash equals gap. I would think you would...
To me lash equals gap. I would think you would still want preload with the hydraulic lifters and I can't think of any reason to run a gap. If anything that would hammer out the circlips on the...
Forum:
THE LOBBY
03-31-2024, 06:26 PM
32
Open trailer with cover on car
1,395
Posted By
lust4speed
It's not the car cover that does the damage -...
It's not the car cover that does the damage - it's the dirt that blows under the cover while driving down the road. Take a nice soft car towel and dust it on the pavement and that's about what is...
Forum:
Pontiac - Street
03-01-2024, 03:35 AM
26
Head bolts loosening
1,652
Posted By
lust4speed
Look the old head gasket over closely and that...
Look the old head gasket over closely and that should tell if water/oil is finding a path. The photo in Post 11 has a very definite and clean imprint and it's a safe assumption that it was not...
Forum:
Pontiac - Street
02-18-2024, 04:09 AM
21
calibrated resistance wire to coil
1,234
Posted By
lust4speed
Might not be a bad idea to mention that if the...
Might not be a bad idea to mention that if the engine isn't running, then the points must be closed while the key is in the run position to check the resistance wire. Open points will be an open...
Forum:
61-66 Big Pontiac TECH
01-28-2024, 03:41 AM
12
66 Catalina to power disc brakes
1,023
Posted By
lust4speed
I went with the 13" rotor Master Power kit on the...
I went with the 13" rotor Master Power kit on the '65 Catalina wagon and very happy with the brakes and their customer service. The rotor and caliper kit was made by Baer, but don't know who makes...
Forum:
Pontiac - Street
01-26-2024, 02:49 PM
76
New member of the 400 Failed Lifter club
4,543
Posted By
lust4speed
The slope on a cam lobe and the taper on a lifter...
The slope on a cam lobe and the taper on a lifter have a lot of margin for error. You need slope and you need taper but it's not rocket science. Now what does come up and bites you hard is lousy...
Forum:
Pontiac - Street
01-14-2024, 03:27 AM
25
The Duke of Oil
3,622
Posted By
lust4speed
Get things squeaky clean, use red Loctite, and...
Get things squeaky clean, use red Loctite, and peen the plug in thoroughly. You probably don't want to tear the engine all the way down but threading the gallery plugs is the best solution.
Forum:
THE LOBBY
11-29-2023, 05:02 AM
10,221
Sticky:
Epic Craigslist Ad of the Day
1,731,855
Posted By
lust4speed
My good friend and high school buddy had a '57...
My good friend and high school buddy had a '57 four-door in the early 60's that he removed the door handles and glassed in the rear doors. Looked considerably like the one on Facebook, but I believe...
Forum:
Pontiac - Street
11-21-2023, 01:42 AM
23
Limited slip question
1,570
Posted By
lust4speed
There is a difference between spinning wheels by...
There is a difference between spinning wheels by hand and launching. The cone and clutch units have springs whose function is to give some lockup in zero traction conditions. Even when new this...
Forum:
Pontiac - Street
11-20-2023, 01:58 PM
62
What air cleaner ???
4,531
Posted By
lust4speed
If you are not incombered by smog laws it would...
If you are not incombered by smog laws it would be hard to argue that a proper breather in the valve cover isn't the best solution. The PCV system operates under varying manifold vacuum conditions...
Forum:
Pontiac - Street
11-19-2023, 10:39 PM
62
4,531
Posted By
lust4speed
That large tube on the bottom of the stock air...
That large tube on the bottom of the stock air cleaners was for the A.I.R. air intake, but really no reason it can't be adapted for the vent tube. Most of the time the crankcase vent was outside the...
Forum:
Pontiac - Street
11-17-2023, 02:23 AM
36
670 head with 068 cam-any benefit to porting
1,853
Posted By
lust4speed
I disagree. You will obtain a noticeable...
I disagree. You will obtain a noticeable performance increase with just porting the heads. Engine is basically a big air pump and the more volume the more power. You can increase volume through a...
Forum:
Pontiac - Street
11-15-2023, 03:36 PM
23
harmonic balancer sleeve questions
1,554
Posted By
lust4speed
Here is a before and after photos of the balancer...
Here is a before and after photos of the balancer with the installation of the Fel-Pro sleeve. The before photo shows that there are different worn areas so either two different seals with the lip...
Forum:
Pontiac - Street
11-12-2023, 03:28 AM
23
1,554
Posted By
lust4speed
I've had really good luck with the following...
I've had really good luck with the following FelPro repair sleeve. Here is a link to it on Amazon but with the part number you can pick your favorite supplier: FelPro 16203 Repair Sleeve...
Forum:
Pontiac - Street
11-04-2023, 02:42 AM
11
Is this evidence of a slipped balancer?
689
Posted By
lust4speed
I can't be the only one around to come back into...
I can't be the only one around to come back into the pit area after running and shutting off the engine and hearing the outer ring continue to spin for a few seconds. Sort of a little alarm to let...
Forum:
Pontiac - Street
10-30-2023, 01:23 AM
13
Helicoil
834
Posted By
lust4speed
Edelbrock exhaust bolt holes are helicoiled, but...
Edelbrock exhaust bolt holes are helicoiled, but they are the only holes to receive the coils.
Forum:
Pontiac - Street
10-17-2023, 01:50 AM
31
Head Gasket replacement
1,416
Posted By
lust4speed
Don't know if the gaskets are the same from years...
Don't know if the gaskets are the same from years ago but the only real complaint with the Butler head gaskets is upon a freshen half the gasket stuck to the block and the other to the head mandating...
Forum:
Pontiac - Street
10-16-2023, 03:05 PM
12
Can I store carb cleaner in a PVC 5 gallon bucket?
732
Posted By
lust4speed
I would say that not all plastic buckets are...
I would say that not all plastic buckets are created equal. My first experience with carb cleaner came decades ago when I used a toothbrush to help scrub gunk off the carb. Noticed a residue on the...
Forum:
Pontiac - Street
10-11-2023, 03:04 PM
60
Torker
2,820
Posted By
lust4speed
I ran down to 10.60 with the old Torker manifold...
I ran down to 10.60 with the old Torker manifold and 1" square bore to spread bore open spacer before upgrading to a Victor. My son grabbed The Torker for his Firebird. He was running a port...
Forum:
Pontiac - Street
10-01-2023, 01:37 PM
8
Oil Pressure gauge
656
Posted By
lust4speed
Your "real time" would be micro-seconds, and as...
Your "real time" would be micro-seconds, and as Schurkey mentioned above all your hard effort will be in vain as air returns to the system. Shut the car off and oil drains back in the pan and is...
Page 1 of 11
1
2
3
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
03:51 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
