Originally Posted by 66sprint6
Is there any situation where the rear sway bar would be detrimental? Like for the ride, for instance. It seems as though for every proponent of a rear sway bar, there is a detractor. I was thinking of installing a factory one, along with the boxed rear LCA's of course, but my son and I installed the air springs inside the rear coils and the handling improved significantly.
Technically, with a sway bar connecting the left and right sides of the suspension, it can have a negative impact on ride quality over bumps. The stiffer the sway bar, the more pronounced that effect will be. However, virtually everyone I've spoken to about installing a rear sway bar on a GM A-body says it's one of the best modifications they've done. I think the pros far outweigh the cons. I'm certainly going to be installing the rear sway bar that came with my UMI stage-3 suspension package once my GTO is put back together.
1966 Pontiac GTO (
restoration thread)
1998 BMW 328is (
track rat)
2023 Subaru Crosstrek Limited (
daily)
