#41
I see it now, missed that. Carry on...
#42
The point is that the engineering has already been done, all someone needs to do is use parts that have been matched already. It isn't hard to buy all the parts from a wrecking yard, and replace them onto another vehicle, it is afterall GM parts, going onto a GM car, made by Saginaw, a GM subsidy. How many GM light trucks gave up their 4L80E parts for a classic muscle car? It didn't come on that vehicle, but it surely can be adapted to work on one.
You can end up with the same mess by buying all Wilwood parts, and mismatching them. If you need an how to article for directions, here it is: https://bangshift.com/general-news/t...-car-or-truck/ It's not like it has't been done hundreds of times, for decades, with success. Having hung around many wrecking yards for many years, and making conversions work with used parts from a wrecking yard on race cars. Before there was the internet, and aftermarket suppliers at your fingertips. It's not that hard to do, using common sense. That's the definition of hot rodding, not getting on the net, and BUYING what you need, then bitching that the aftermarket vendor sucks because after you bought all his parts, and you're not getting the results you wanted. It's hydraulics, and physics, sometimes you have to figure it out. If you want someone else to figure it out for you, then you pay them for figuring it out for you. It's not impossible. |
#43
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '69 LeMans Vert, 350, #47 heads: work in progress |
#44
You don’t see road race cars running power brakes in classes like GT1 , go manual.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
#45
I have fuel rails too, but just need to kind of turn the cover towards the intake during removal and it comes off with no problems. EDIT: Added a pic of the clearance with the Anchor engine mounts too, but you may have to zoom in. .
. 1970 GTO Judge Tribute Pro-Tour Project 535 IA2 http://forums.maxperformanceinc.com/...d.php?t=760624 1971 Trans Am 463, 315cfm E-head Sniper XFlow EFI, TKO600 extreme, 9", GW suspension, Baer brakes, pro tour car https://forums.maxperformanceinc.com...ght=procharger Theme Song: http://www.youtube.com/watch?v=7zKAS...ature=youtu.be Last edited by HWYSTR455; 05-25-2024 at 06:36 AM. |
#46
This is great Mike, thanks! Any issues removing valve cover?
#47
Because of low vacuum, use of cannister that didn't solve the problem, and even a vacuum pump for awhile, and still brakes that didn't instill confidence, I contacted Wilwood for my conversion. Speaking with the tech at Wilwood when I ordered thier discs and calipers front and back for the conversion on my 455 76 TA I was advised to go hydraboost since I decided not to go manual. By the way I like both. I bought the Vintage Speed Reaper System (Tallon Hydraulics??) out of MI, and installed it 2017. Wow, seven years already! It came with the Willwood master 260-8556 with 1 1/8 bore size for my application, proportioning valve, and a CNC mounting plate and etc. The install was a direct fit and relatively easy but instead of using the included lines and fittings that needed to be crimped on, I opted for professionally made-to-fit lines from a local hydraulic company. The system has been flawless and a night and day improvement, and great confidence. More sensitive than the original set-up but not an issue. Just my two cents to hopefully help.
#48
Sorry I missed this, but no issues removing the cover, as long as you don't get impatient. Like I said, if you lift up slightly and turn the cover lengthwise towards the intake, and then lift up, all is fine.
If you get impatient, worst case, the gasket will get pulled off the cover if you glue it to the cover. .
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
