Old 09-04-2014, 02:34 PM
HWYSTR455's Avatar
Default 70 Judge Tribute Build
So the driver is due for a refresh, and felt since I was going to go through it, might as well make it something worth while. I've always like the 70 GTOs, the styling is killer, the sheet metal is all available, so it makes sense to go in that direction.
I did the 442 tribute for my daughter, she loves it, so figured I stick with a winged car and make it a Judge for my son (he's inline for a classic).
Figured I'd track the progress here, and if I need any help or anything, what better place to go?
General Project Outline: Clone a 70 GTO Judge from my 71 LeMans Sport. Modern comforts, overdrive, AC, sound and thermal control, nice sound system, and low maintenance.
Here's a shot of what I'm starting with, many have seen posts of this car over the years, at PY shows, cruises, etc.
Also attached is a couple of examples of the direction I'm going, either an Orbit Orange or an Atoll Blue, and obviously, this build isn't going to be correct, just a 'tribute'. If I grabbed someone's car here, um, thanks!
ID:	375301   Click image for larger version
ID:	375302   Click image for larger version
Old 09-04-2014, 02:41 PM
HWYSTR455's Avatar
In preparation for the build, one item I purchased early on was an endura, and sourced it from EnduraBumper.com. I did another thread on this, and gave them a plug, feel the service and quality was worth a mention.
Obviously the proof will be once it gets mounted, and how it fits, but I've seen a number of endura bumpers in my time, and this one seems pretty nice. When the time comes, I will post more regarding.
Old 09-04-2014, 02:54 PM
HWYSTR455's Avatar
Getting right to it, the tear down begins. I blew the front clip off, and pulled the engine and trans.
Someone was interested in purchasing the front clip, but for some reason, we couldn't come to an understanding. (will be listing it in the parts section soon)
Also there's a shot of some assembly line markings on the cowl, not sure what they mean, but figured I'd include the pic for others' possible interest.
Some of the pics are out of sequence, but you get the idea....
ID:	375305   Click image for larger version
Old 09-04-2014, 02:58 PM
HWYSTR455's Avatar
In case anyone questions if I drove this car hard or not...
Got the tires mounted on the new wheels, US MAG 18x9s, and got the rally center caps for them, should look good.
ID:	375307   Click image for larger version
ID:	375308   Click image for larger version
Old 09-04-2014, 03:07 PM
HWYSTR455's Avatar
So before I take the body up to the body shop, I needed to change the body bushings, since with worn out bushings, you can't do any panel alignment. I was tossing around the idea of possibly having the frame blasted and powder coated, and finally just said what the heck, and dropped the frame.
I used angle iron and bolted it to the forward pinch weld where the fender bolts to the cowl, and lowered it on to jack stands.
In the rear, I used angle iron on the bumper mounts, and lowered those on some 6x6 posts.
I gutted the front suspension and most of the rear, but you could drop it and roll it out if you wanted to. I did leave some of the rear suspension and the exhaust in place, and just removed it after the fact.
I know it looks shady, but believe me, it's not going anywhere, and is properly supported! I shook the whole thing a bunch beforehand, just to make sure the stands would hold it.
ID:	375310   Click image for larger version
Old 09-04-2014, 03:15 PM
HWYSTR455's Avatar
So I got the frame loaded in my POS truck, and hauled it to the blaster and powder coater. Turned out pretty good, and just for reference, to have the bare frame blasted and powder coated cost me $750 in my area, which is probably a little more than most, but I am in a greater metro area.
As a suggestion, if you're going to do this, I suggest you take some time and clean up welds, slag, etc, and have the frame checked for cracks and repaired as needed.
I looked into boxing the frame but figured for my build, it wouldn't be required. If anyone is curious as to my logic, feel free to ask.
ID:	375314   Click image for larger version
ID:	375315   Click image for larger version
Old 09-04-2014, 04:53 PM
Chastings's Avatar
Chastings Chastings is offline
Excellent thread! Looks like lot's of progress
Old 09-05-2014, 06:51 AM
HWYSTR455's Avatar
Thanks! Oddly, it actually has gone pretty fast up to this point, kind of surprised. Took like 4 or 5 hours to take the front clip off, like 2 hours to remove engine and trans, about 4 hours to gut the interior, and about 6 hours to remove all the suspension and the frame. The time it took to remove the suspension and frame includes cleaning up the parts coming off as well.
So spoke with Doug at Global West like a week ago, and got all the stuff ordered to freshen the suspension. Hope that stuff will be here today or so.
Engine was dropped at CVMS couple weeks ago when I pulled it, and the trans was shipped to CK Performance to be freshened up.
So the plan is to get the suspension done, frame installed, engine and trans installed, then take it to the body shop. That way it can roll around and the body shop guys aren't burdened with moving the hulk.
Also going to prep the firewall and underside before I take it to the body shop. I'm going to use a Vintage Air AC setup, and because of, will smooth the firewall. I purchased a smoothie panel from ABC Performance, and should have the firewall prepped and the panel tacked into place by the end of the weekend.
The underside I'm going to clean up, wipe down, and coat with truck bed liner. There's some minor repairs that need to happen on the floor pan cross braces, seems a couple small areas held water and rusted a little. Think it's like 2 spots of like 2" by 2" at most, not enough to even purchase pans. The braces I'll hit with some Eastwood internal frame coating once the patches are done. Luckily, when I first got the car in '91, I pulled the carpet, wire wheeled the whole floor, and POR-15 it. Saved it.
Old 09-05-2014, 08:42 AM
pggto's Avatar
pggto pggto is offline
Where is Endura Bumpers? There webpage doesn't tell you were there located.
Old 09-05-2014, 09:07 AM
2002Z4CSS's Avatar
Keep the pictures coming.
1971 Pontiac GT-37
Old 09-05-2014, 09:53 AM
HWYSTR455's Avatar
I would have to look at the receipt as to where they are located, don't remember off the top of my head. There's a YouTube site and a FaceBook page, neither have that info.
Old 09-16-2014, 06:43 PM
HWYSTR455's Avatar
Looks like EnduraBumper.com is in Indiana, but still haven't dug up the receipt.
Anyway, couple updates here, and at least I will post a pic!
Got the firewall prepped for the smoothie plate, ground the raised lips, beat a few high spots in, and wire wheel the top/cowl area. Had to dig out a bunch of seam sealer on the top, and sides of the cowl, wire wheeled the groove, and went heavy on the POR-15 in the seams.
On the firewall, I mocked up the smoothie plate, used a sharpie and outlined it, ground/wire wheeled about a 2 inch path on either side of the sharpie line, and shot it with zinc weld thru primer. (Holy crap that's stuff is $31 a can!) I also hit a number of holes that were for firewall pad push retainers, and a few other holes that 'appeared' thru normal use, and will weld those as well.
Broke a windshield removal tool, it's an older one, so couldn't get the windshield out this past weekend, but ordered a new one, hope that will come in before next weekend.
Got a call from Jim at CVMS, seems the engine will be fine with a re-ring, new bearings, and general clean up. Will do a new cam and lifters, still trying to decide what I'll do there. I will give a break down on what was done etc once I get to that point and will post.
Also got a call from Chris at CK Perf, the trans is done, had to replace a few hard parts, did new frictions, and ordered a lower stall converter. (@2600) . Both shipped today, so should have it before the weekend. The original converter, which was @ 3000-3400 stall, I have getting freshened up, and will re-use on the 442 in the spring. (it needs an overdrive bad)
So I have some work to do, need to get the firewall and underside done before I bot the frame back up, then need to knock out the suspension to a point where it rolls, drop the engine/trans in, and take it up to the body shop by the 3rd or 4th week of Sept. . Whew! Or that's the plan!
Old 09-16-2014, 08:06 PM
Held for Ransom's Avatar
Trunk key code and maybe the sequence number for line-up of car for the day built. Pontiac plant built?
Old 09-16-2014, 08:46 PM
HWYSTR455's Avatar
Hm, not sure, but I do have the PHS on it, maybe I will dig it up and post info.
This car was ordered by a Pontiac dealer owner for his daughter to drive to college. It was not badly optioned, 71 LeMans Sport, lucy blue, PB, PS, AC, tuxedo interior, and vinyl top. 350 2bbl auto car. I bought it from the second owner, and it had about 69k miles on it as I remember, think I paid 2600 for it in '91, there again, I would have to check, but pretty sure. At one point I had someone approach me stating they knew the original owner, the girl who drove it to college, so the history I got from the second owner was validated. I bought the car specifically to use as a tow vehicle for a boat I was planning on buying, put a 400 in it with a Th400 and a 12 bolt 373. I bought a house instead of the boat, and the car ended up being a driver. I drove the car as my primary transportation pretty much until about 2010, and it's had like 7 or 8 engines in it, and I would freshen the engine or replace every @ 100k or so. My kids grew up riding in this car and it's a piece of the family. This go around, when it's done, the plan is to give it to my son (my daughter got the w-30 clone).
Here's a shot of it from like 1993, I had just put an H-O Strong Arm suspension on it, and 16s from like an 88 T/A. Trivia: My kids, young at the time, were ducked down in the car when I took this pic.
Old 09-21-2014, 09:23 PM
HWYSTR455's Avatar
So my buddy came over and welded the smoothie plate in today. Only took minor doctoring, a few slight high spots, and a little trimming of the panel. Held it up there and started tacking it into place.
He did like 4-6 inch spacing between the welds, started at one side, and worked his way towards the center of the firewall. That he said would prevent having the panel under any kind of tension.
Once he made a pass, he went back and started filling in the spaces. Hit it with a grinder with a course sanding disc on it, ground the welds down some, checked for open areas, and hit any remaining.
He's going to come back on night this week and do a slight bit of filler, sand it out slightly, and it will be ready for seam sealer and paint.
ID:	376887   Click image for larger version
Old 09-22-2014, 02:24 PM
HWYSTR455's Avatar
Also got the frame installed over the weekend, set the ABC solid bushings in place and raised it, got all the bolts in....
Did the underside in truck bed liner, though there are areas I left exposed so some minor repair can be done (without catching fire). I'll touch it up once it comes back, not a problem.
Will get the suspension parts cleaned up, a couple may need a touch up with a rattle can, but for the most part, it's all ready to bolt on. Have new hardware, a good number of new parts, shouldn't take long to get it rolling.
Engine is close to being completed, will bolt it to the trans and drop it in before I take it up to the body shop.
ID:	376948   Click image for larger version
ID:	376949   Click image for larger version
Old 09-22-2014, 03:07 PM
2002Z4CSS's Avatar
What kind if material are the bushings made from?
1971 Pontiac GT-37
Old 09-23-2014, 08:26 AM
HWYSTR455's Avatar
T6061 billet:
http://www.abcperformance.net/body%20mounts.html
They're the ABC Performance ones.
Old 09-28-2014, 09:04 PM
HWYSTR455's Avatar
Got the smoothie panel finished, primed, and ran all the seam sealer. Then shot it with a initial coat of paint. Seam sealer should be cured by tomorrow, so will shoot the final coats after work.... (sorry for the quality of the shots, got lazy and used my phone...)
ID:	377476   Click image for larger version
Old 10-08-2014, 10:45 AM
HWYSTR455's Avatar
Here's a better pic of the finished firewall....
Thread Tools
Display Modes
