Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
race parts
Pair of AP header flanges that were separated for custom removable header tubes. I decided to go with stainless and did not use these. 5/16" thick. 2 1/8" tubes. $65.00 shipped
New Nitrous Pro Flow bottle warmer. $100.00 shipped Ultradyne cam grind number: 324/336 R114. Cam made 900+hp in a 541 Rebuilt Crower lifters number 66295H. Offset intake. Lifters have 7 passes on them since rebuilt Cloyes double roller timing chain. Has 7 passes on since new. $700.00 plus shipping New, never used wet sump external oil pump oil pan with belt drive front on it. $400.00 plus shipping AED 750 HO carb (4150) that was used on my dads car for engine break-in. couldn't use it with ram air setup. Build date on carb was 1/29/99 but was not used until March 2010. I have build/spec sheet from AED. Used for start ups only for a few months then removed and put on shelf. $300.00 plus shipping.
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
more pictures
Is that a custom number on the cam? Can you give more specs: lobe lift, duration, etc.
Is the cam hydro or solid? Thanks, Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, TCI Flex plate, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. |
its the number on the camcard. was used with the solid lifters listed
Mark
Might be interested in the lifters if you sell the cam seperately.
1979 TA 541/T56 Magnum 1964 Catalina 462/TKO600 1965 GTO 389/4speed |
Pm sent
header flanges sold
Aed carb
pm sent
pm replied
PM sent on pan
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
AED carb
Jim did you receive my pm from 9:14 last night?
sent via email.
Aed carb
Pm sent
carb and bottle warmer sold
AED carb
Thanks Jim,currently in New Orleans have someone to receive the package in jersey.
Hank |
