Fuel delivery issue
72 GTO, basically stock
Car was idling in garage and just stopped. Was able to get car running again but only after re-filling float bowl and only until bowl empty. Replaced fuel pump (Ames N128RC) and rubber lines going into pump, didnt fix the problem Tried running car off external fuel tank, didnt fix the problem (should have done this before replacing pump) Rebuilt Quadrajet with kit from Cliff R. Car will still only run off fuel in float bowl for about 10-15 seconds then dies Engine was rebuilt many, many years ago but only about 1,000 miles on it since then SS fuel line from pump to carb looks fine with no leaks....could there be an issue with the fuel eccentric or am I missing something else? |
Its process of elimination time!
Pull the carb , remove the air horn and confirm that the float or the needle is not hanging up. Today fuel turns to gummy crap really fast!
My apologies, I guess I wasnt clear
I just pulled the carb and rebuilt it and put a new pump on it also in trying to find the issue. Unfortunately I am running out of ideas. Can a fuel pump eccentric go bad somehow? |
I am using a stock (Carter) fuel pump. The manual refers to it as a vapor return line, is that what you are referring to Gary H.?
Sorry for whats probably a dumb question... It would probably make more sense than my math, lol Last edited by dv657172; 12-06-2023 at 05:23 PM. |
With the pump off you can look thru the hole at the eccentric and make sure it's there, and attached properly.
Check for dry rotted lines between the tank and the pump. Make sure all the clamps are tight too. I've seen them not suck fuel and not leak either. If they're old, replace them. The old stuff isn't made for today's fuel and will eventually fail. Something stuck in the fuel line itself may allow air to pass back to tank, but plug again from the tank forward. It's possible. Like a bunch of rust flakes at the bottom. Or globs of thickened crap. If you've never had the tank out, it wouldn't be a bad idea to pull it and inspect it. Yank the sock off while you're at it. Pop the sending unit and look in there, shake it around, see if there's crap in there. Bet there is. If there's a question over the vapor line, plug it. It's possible to get multiple DOA/out of box failures on the pumps, Paul Spotts just went thru this. Think it took him several before he got one that worked. The Carters were the ones failing, and he was going to try an airtex I believe. Pretty sure he picked up a NAPA one. .
When you installed the new pump did you feel the arm load in and load up under the pump eccentric ?
How did the arm on the old pump look if that looked ok then I would have to say that you need to drop the tank and check to see if the filter sock has collapsed or if it’s just plain clogged off. Before going thru this dropping of the tank if you have a air compressor take the fuel cap off the tank and blow air back Thru the line from the pump. Have someone listen at the tank filler neck for air going into the tank. Also be ready for a rush of fuel coming back out at you once you stop the air if the sock was blocked off .
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 12-02-2023 at 04:27 PM. |
Thanks for the ideas
I attached a pic of the armature wear on the old pump. I thought the armature on the new pump had a small load on it although it wasnt too hard to put in. I have only done a few over the years but successfully...at least so far I guess I will try to run car off an exterior gas tank again and if that doesnt work I would assume its not a tank issue. If it does run off the exterior tank than I will try the tank ideas. I thought you could replace the sock without dropping the tank or is that for earlier models or not at all? |
That’s strange ware on that arm, kinda like the eccentric is warn weird or is wobbling, I mean there’s no sign of any center ware.
Anyway try running it off a gas can .
could you just hook up a rubber hose to where the fuel line goes into the carb? then have someone crank the engine to see if fuel comes out into a can of course.
72 Luxury Lemans nicely optioned |
The Following User Says Thank You to indymanjoe For This Useful Post: | ||
This ^^^
I had the fuel pump eccentric loosen on a Dodge truck one time. It took weeks for me to find the problem. It was intermittent. It would only act up in the afternoon on my way home from work, never in the morning on my way in. After weeks of troubleshooting when the truck finally just refused to start I was able to verify that the brand new pump wasn't pumping fuel very much at all. When I actuated the pump by hand it shot fuel six feet. I suspect that the eccentric mounting bolt had loosened and it was spinning on the camshaft?
I never went into the timing cover. I blocked off the fuel pump opening and installed an electric pump.
Greg Reid Palmetto, Georgia |
Rather than try to run the engine off an exterior tank I will just run the line from the pump to a jug and run engine off the float bowl to hopefully pinpoint if its a pump or pump related issue
2 questions How much fuel should go into the jug if the car only runs for about 10 seconds (stock fuel pump)? Is it about right for the engine to run off the float bowl for only about 10 seconds before dieing when the float bowl is not being refilled? |
I would say 10-15 seconds to empty the bowl isn't out of line.
Fuel filter installed the right orientation?
The above is a much overlooked point!
If you installed a paper filter the wrong way then the anti-drain back valve will not allow fuel in.
The Following User Says Thank You to steve25 For This Useful Post: | ||
As far as I know it is....but worth double checking. Which way is correct to be sure?
I thought they could only go in one way, at least according to the service manual. |
Spring goes in first, then the filter with the "closed" end facing the carb, "open" end facing the fuel line.
The Following User Says Thank You to jhein For This Useful Post: | ||
Some progress....
I did put the filter in correctly as the car ran today off an exterior tank for about 15 minutes which it wouldnt do previously even after I had replaced the fuel pump. So I assume there was was a carb (float or needle/ seat) issue which got resolved with the carb rebuild I did after I had already replaced the fuel pump. However as mentioned earlier it wouldnt run yesterday off the cars fuel tank so I will try Steve's idea on blowing air through line and seeing if sock is plugged before hooking fuel line back up to the tank. Its never straightforward.... Appreciate all the help and advice, will keep you updated |
I had a sock failure on my78 Trans Am one time on a trip to Denver.
Jacked the vehicle up with the vehicle jack, removed the fuel sock (melted shut from bad racing gas) and reinstalled the pick-up. Engine fired right up and we drove another 1500 miles on the trip without an issue. Bad gas caused the melted fuel sock. TV
Sure couldnt afford to go 1500 miles on racing gas nowdays at $10 gallon, lol
