Aftermarket Top Rad Hold down
I'm going from mechanical fan to electric fans with a shroud. Looking for a supplier that sells a top plate that holds down the rad. I've seen them before somewhere.
Something like this should work. https://www.summitracing.com/parts/s...2b?seid=srese1
Are you going with fans like this with the shroud? I find they work really good as they have the rubber flaps that also allow air to flow through the radiator at high speeds. https://www.summitracing.com/parts/t...06?seid=srese1
https://www.summitracing.com/parts/der-16927
The Following User Says Thank You to ta man For This Useful Post: | ||
Are you doing the electric water pump at the same time?
I was going to ..but looked at the cost of a pump and a new belt setup..too pricey for now. Maybe if I start racing more.
Something similar to that Summit part but would like four holes in the factory location.
Find a busted shroud and trim to taste.
That will get going until I buy or make something.
Only reason it says that is due to the dual fan shroud but can easily adapt with a little effort.
Take a look at this pic and others on the listing and it will be more clear. .
