#121
Does anyone have info about wheel well space in a 1964 Bonneville? I was looking at 15x7in or 17x7in American Racing 200S "Daisy" wheels but they only come in 4in backspace. Does anyone know if this will fit if i run a 205/60 (15in) or 215/45 (17in)?
Further complicating the issue is my car rides on air suspension and i dont want the car resting on the wheels (which will push on the bodywork) when it is aired out. Narrower tyres should help this but i am concerned the outer edge of the wheel will contact the inner face of the guard/fender Currently i have 15in Cragar S/S with 205/60 tyres. I dont mind altering the rolling diameter (by running smaller tyres) as i will have to run a speedo adapter to suit the TH400 i have installed to replace the dead Super-Hydro 4spd. |
#122
Autocrossing, diesel loving, tri-power loving grandpa Architect |
#123
What do you say about 15x7 wheels with 4,25 backspace and +6 offset
or 15x7 with 4,5 backspace and 0 offset? Would any of them fit a 66 Bonneville with fenders and if so, what size of tires would be best?
66 Bonneville 4-door Hardtop - Sold - But it has its own thread here 66 Bonneville Wagon - Sold 63 Grand Prix - Sold Last edited by 66 Wagon; 06-20-2017 at 03:04 PM. |
#124
I don't know from experience but my guess is they will work. Don't take my word for it though!
#125
4.25" backspacing should work depending on the width of the tire and may still be tight. Don't think the 4" will work with skirts.
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
#127
I Have a 67 GP with 15x6 Rally's and 225/70-15 tires. Plenty of of clearance in the back on both sides. I just ordered 17x8 Cragar 69 wheels with 4.50 backspacing and 0mm offset. Will be using 225/60-17 tires. Same height and width. Should be no issue from what I can tell.
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege" www.musclecarsgalore.com www.nikivee.com [www.reverbnation.com/nikivee 1967 Pontiac GTO 1967 Pontiac Grand Prix 1972 Pontiac Lemans Sport Convertible 2015 Dodge Challenger ScatPack 392, 6 speed 2017 Ford Explorer AWD |
#128
I hav a chance to get some nice wheels to put on my 64 Catalina but after reading this sticky I'm more confused then when I started. The wheels are 15 x 8 with a 4" back spacing. If they will work what tires are recommended
Jeff |
#129
I'm ready to buy tires right now and am more confused than ever. Someone, my mind is slipping and I can't find the info, posted pics of his '66 (65?) Bonnie with 235/75/15 with 8 lugs and he says they fit wonderfully with no issue (with skirts). But from what I'm seeing here they shouldn't fit (or am I mistaken? I'm usually great with numbers too! lol)???
Anyway, I just want to get a nice wheel for the 15" steelies with poverty caps 15x6 wheels and can't figure out what will fit and look good. Will 235/75 fit? Or should I go to 225/75? 235 or 225 with 70%?? Thanks
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console 1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats 2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather |
#130
Hope this helps some.
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
#131
I tried to get 235/75/15 on my car and they weren't even close to fitting (with skirts). I was thinking that because I have 4 wheel disc brakes added that if I remember correctly the brackets from Scarebird push out the wheels a little bit over 1/2" and that may be causing my problems.
I went with 215/75/15 ... and am wondering if I shouldn't use 215/70/15 instead ... I'll ride around for awhile with what I have and see how I like the look, feel, and handling.
#132
From a separate post made on 8-24-19:
#133
I’m running 15x8 8 lugs with a 275/60/15 drag radial. Good clearance on both sides. 64 Catalina
1979 TA 541/T56 Magnum 1964 Catalina 462/TKO600 1965 GTO 389/4speed |
The Following User Says Thank You to TransAm400 For This Useful Post: | ||
#134
man this looks amazing
#135
What back spacing on those wheels?
Phil '63 Grand Prix / 389 Tri-power |
#136
275/60/15 on a 15x7 wheel with 4.25 back space.
Mike McCarty You can drop the line, but you'll never kill the spirit! Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far |
#137
**Revival**
My 1966 STARCHY has some 15x14" wheels & 470/43/15 tires The tires dont have lots of room but are 31"x18.5”-15” and tucked in nicely Last edited by Zooguy; 07-27-2023 at 02:38 AM. |
#138
^ Yes, but it also appears your car has some serious wheel tubs.
The Following User Says Thank You to Stuart For This Useful Post: | ||
#139
Looks good Troy. You gonna put dog dish caps on those wheels?
" Darksiders Rule "
#140
Dont have the caps on yet but these are the ones
