Pyle Bros has worked on several for me -and an hour in good traffic from this side of town.
The Impala project will be getting a 9" already have a pumpkin with a 3.50 Pyle Bro freshened for me, housing will need the extra upper link to make it a 3 link not three. Not all the suppliers of housings have that option.
One thing that's worth looking into is whether Quick ships them assembled or if that is on your shoulders. A 9" is pretty easy to assemble, though, so even if it's not, that's not too big of a deal.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
![]() Quote:
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
![]() Quote:
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Care to explain the big difference here and why it matters?
Well now, this is a new one on me. Care to explain this as well? |
There is a difference (to me) between using used Ford factory 9" housing/tubes/ends than using a new housing with 1/4" thick tubes. QP offers both. I'm not saying everyone needs a new housing, I'm making the point that a similarly built QP 9" is almost as much as a Strange/Moser 9". QP offers 8 different center sections from stock Ford to Yukon, Strange and Moser. That's the only point I was making, take it for what it's worth.
I went with the quick performance. I went with the new center section, 1/4" tubes, jack plate/drain, fill option, 35 spline axels, stainless ends on housing, adjustable lower brackets, Yukon center section, disc brakes, helical gear posi and powdercoating. Ordered on black Friday for 10% discount was 2900 delivered. Probably overkill but 500 hp at rear wheel on motor plus 150 shot with a clutch and slicks I prefer to be sure nothing breaks.. I do like to play hard.
Nice rear, that's a one and done for some serious power. What do you have for a driveshaft?
Trying the steel one that came with the T56 Magnum package..
One option I discussed on the phone with Max from Quick Performance is eliminating the coil springs and shocks with an adjustable strut. (I hope I'm using the right terminology) Basically a shock with a spring surrounding it that allows for ride height adjustments. I had them on my 89 Mitsu/Chrysler Conquest TSi.
The point to doing that is a previous owner installed red color air bags inside the coil springs to slightly raise the rear height (NOT Hi-jacker style) and if I can improve the rear end suspension by going this route, now is the time. Opinions/experiences? Thanks! Also I posted a screenshot of the QP options that I selected, and new center section was selected. I am not aware of any Moser or Strange dealer that I can get a similar setup from for anywhere close to 3k, unless you call 4k "close". Max's explanation for their price savings was "dealer pricing" for all customers as they do not have a dealer network sales system like the others. Last edited by avman; 01-14-2018 at 12:28 AM. |
Lol. No problem. Thanks for the info.
3 pix I had handy
I just bought a 9 inch from quick performance with Thru Bolt aluminum center section and all the goodies like helical posi and everything. The center section was 1404 exactly shipped. I used the yukon unit. The rest of my housing I got crazy with and ordered the explorer disc brakes and everything so you cant use mine as a basis but it was about 2500 all together. Way cheaper than anyone else with similar options. Also I got Moser Axles.
![]() Quote:
Quick Performance - New housing (optional; included in price below) - Drain & Fill plugs - Jack pad - 1/4" axle tubes - 3.7 gears - Detroit Locker w/31 spline axles - Yukon Pro N center section w/billet pinion support - 11" disc brakes w/parking brake + braided hoses - Powder coated Total: $2999.00 Moser - New housing (standard) - NO drain/fill plugs or jack pad available (on website, anyway) - 1/4" axle tubes - 3.7 gears - Detroit Locker w/31 spline axles - Nodular iron center section w/billet pinion support - 11" disc brakes w/parking brake + hoses - Powder coated Total: $4010.00 Currie Enterprises - New housing (standard) - Drain & fill plugs - 1/4" axle tubes - 3.7 gears - Detroit Locker w/31 spline axles - Nodular iron center section with iron pinion support - 11" disc brakes w/parking brake - Powder coated Total: $4,311.20
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 01-14-2018 at 02:40 PM. |
That is basically what I've been saying! Moser, Currie, Strange...ALL "around" $4,000 but Quick Performance, nicely optioned (powder coat alone is $300) only around $3,000!!
See attached (not final, depending on the "strut" option that would eliminate coil springs). |
By the way, the 4x4 and classic muscle car suspension specialty shop that swapped in the 4.10 ring and pinion gears in the Dana 60 in my 70 Roadrunner, and previously resolved another problem for me, that has explicitly EARNED MY TRUST recommended EATON for the posi section. Y'all have been VERY helpful as well, so i have faith in your recommendations as well. DETROIT LOCKER VS EATON?? Opinions/Experience? Thanks!!
It's my understanding that the Eaton Truetrac and Detroit Locker engage differently, and there are pros & cons of each method. The Truetrac is known for engaging/disengaging less abruptly, making it more suitable for a street driven car. Detroit Lockers are more severe and can make some racket when making tight turns (like pulling into a parking spot), but are the more bombproof design (or so I've been told). You will likely find people firmly in both camps.
#38
![]() Quote:
Any input on the strut option to eliminate coil springs and shocks and air bags? I am inclined to go that route! |
#39
![]() Quote:
Now, regarding coilover vs. stock configuration suspension, if all you want to do is get the ride height exactly where YOU want it to be, installing coilovers to achieve that is way overkill. They sell standard springs for stock and lowered ride height, and if you want to raise the rear, you can buy spring spacers for $40 or less. Compare that to the $800-1000 you'd spend to buy a rear coilover setup. Basically all I'm saying is that you can fine-tune your rear end ride height by simply choosing the right spring and maybe using an inexpensive spacer if needed, and it will be far less expensive and complex than doing a coilvoer conversion. Hopefully others will chime in with their opinions and correct me if anything I said is off-base.
#40
![]() Quote:
