Not dead just not cheap factory spec cams are available from kanter and egge just not the H cam. and if you are looking for something more radical then you are in regrind territory untill someone makes more blanks. Overall kost of the parts for the OHC-6 are out there cams are the only difficult item
When you really do something right it's like you didn't do anything at all 1931 Pontiac 5 window coupe OHC6 powered 2015 GMC Yukon SLT |
why not use up all the castings that are already made ,before you condemn it to death.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
I put a call into Isky to see what they say
is there a list of what cam came in all the engines 230 and 250s?
Jon Peters 66 tempest 3880 lbs with driver 455 .40 over, 6x, XE274H cam, th350,9 inch 3.89, 275/50/15 mt dr 13.04 et / 102.51 mph 11.97 et/ 113.68 mph w/150shot 75 Astre Turbocharged OHC 6, TH350 1/8 mile stats 8.4813 ET / 82.07 MPH |
Here is what I have on file;
Camshafts Casting#s 9782012 66’ (E) 1BC 9782218 66’ 4BC 9792538 66-67’ (E-D) 4BC 9790826 68’ (C) 1BC. GM# 546670, 546671 Gr# 0.519 9792539 68-69’ (E) 9796327 69’ (H) 4BC w/MT. GM# 546673
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Thread Tools | |
Display Modes | |
