I've got 2.5" pipes with an X and Ultra Flows and it drones like crazy at 2k rpms. Outside of the drone zone they sound great.
Chris D 69 GTO Liberty Blue/dark blue 461, 850 Holley, T2, KRE 310s, Comp HR288 w 165s, RA manifolds, T400, 9"w 3.50s, untested The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
PYPES X system in both cars - 66, 69 GTO - with the Race Pros which I like a lot. There is a bit done but definitely not fatigueing
Jones Max Flow mufflers or the new Flowmaster FlowFX mufflers.
Not sure where you are located but I have a 3" Pypes w/ X pipe, Dynomax ultraflows from headers to tailpipes in good condition I just took off a 78 T/A because I wanted to go back to a cross flow muffler. If your interested. PM me. Located in Jacksonville Fl
These Xcelerators are interesting but no one promotes them but RamAir Restorations.
Thank you. There is a hands width between floorboard and muffler.
I would love this sound. https://www.youtube.com/watch?v=BoQdGQpwZk0
Be careful!!!!! Oh, dynomat, lol.
1971 Pontiac Trans Am Cameo White 1968 Firebird 400 coupe, Verdoro Green w/black vinyl top 1968 Firebird 400 convertible, Verdoro Green w/black top 1970 Buick Skylark Custom convertible(driver) Fire Red 1972 Buick GS 455 Stage 1 Royal Blue |
I use the FlowFX on my 66 GTO (462cui) and there is very little drone, nothing I would complain. I use an H-Pipe and 2.5" piping.
Just a nice deep sound |
Jones Max flow mufflers are similar to the dynomax or goerlich designs, oval case, offset or straight through, perforated tube surrounded with noise suppression packing. I use the ones available on ebay. About $40 each. Sound great with no drone.
Home of WFO Hyperformance Shaker induction. |
The Following User Says Thank You to Larry Navarro For This Useful Post: | ||
Tom Hand recommended these to me over 15 years ago. I've used two sets, one on a low-11 Pontiac and the other set on a mid-10 stroker Ford Windsor. Great performance, surprisingly quiet (for the large case versions, at least).
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
This thread makes me appreciate my military related hearing loss.
I run 3 inch electric cutouts, and they dumb right behind the driver's door. I made a 3 hour road trip yesterday with them open, and it didn't bother me a lick. I really like the stupid face I get from Prius drivers when I drop a gear and pass em at WOT. It's only when the sound bounces off their car that I really notice it.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning. |
I installed a 2 1/2" Pypes X pipe system on my '64 GTO in 2010. I used the Pypes mufflers, the quietest of three they offer. It's a 4 speed, 428, with '67 HO cast iron exhaust manifolds, 3.23 gears, so I'm running about 3000 rpm at 70 mph.
There is no drone whatsoever. The sound is a little "raspier" than stock OEM mufflers, but quiet inside the car while on the highway.
The Following User Says Thank You to Dick Boneske For This Useful Post: | ||
Another example of the XLerators: https://www.youtube.com/watch?v=R2Od_KQq1ms It does boil down to personal preference at some point, but with H or X pipe, either I have never had any drone with over the axle tailpipes. .
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
#38
Maybe I missed it, but I assume you have tail pipes and not just dumps at the mufflers?
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
#39
Yes, tail pipes and X pipe.
#40
Dynomax super turbo 17749
The Dynomax Ultra flow will still drone.
Get the #17749 DM super turbo (offset/offset) with 2.5 pipes and it will rumble like stock muscle from 70s and still roar a bit when you mash it down. Its the only way to go if you value your ears, sanity and want to be comfortable on long trips talking to people in your car or on phone.
1974 Lemans Sportecoupe GT (daily driver) .030 over 354, #47 heads (84cc), Lunati voodoo 700 camshaft (207/213 @ .050), logs, 2.5 duals, X-pipe and Dynomax super turbo mufflers, 3.08 rear |
The Following 2 Users Say Thank You to moontower69 For This Useful Post: | ||
Thread Tools | |
Display Modes | |
