#121
Ken, you are crushing this! May the karma gods be shining on you and your round port heads.
The Following User Says Thank You to will slow gto For This Useful Post: | ||
#122
Got my decals ... Love Them
I'm World's Best Hyperbolist !! |
The Following User Says Thank You to dataway For This Useful Post: | ||
#123
Ok Dennis, here's a pass at the 455 HO emissions label. This one is deceptive - seems simple, but there's a bunch of details to capture...and I keep finding them when I think I have it. Fonts could use a little more massaging in some places. I'm guessing they moved on from water slides to stickers at this point?
And a pass at the controversial and elusive '69 emissions decal. Without an original, I assume it would be based on the '68 style but I don't really have enough to go on. I won't produce this one unless someone comes up with an original. Reading through old threads, it may have even been paper.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post: | ||
#124
Wow, that's so good!
The use of all the "periods" for abbreviations and incomplete sentences caught my eye. I view it as part of the history and nostalgia - the transition to digital everything. As we all started typing, adding punctuation became a nuisance and the styles changed. |
#125
And...I just noticed a typo on step 6 in the mockup above so here's a new one. I'm not sure the type is exactly right for the steps. Looks a little heavier in the original, but I'll see how it outputs.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) Last edited by Verdoro 68; 02-28-2023 at 01:54 PM. |
#126
It is a decal, not a water transfer, but seems to have a clear vinyl protective cover, or coating (?) on it...maybe? Thanks for your fantastic work! Dennis |
The Following User Says Thank You to SD455DJ For This Useful Post: | ||
#127
No worries, lets get it right! I'll keep messing with the line work trying to find a good compromise on weight. I had it heavier, but it looked TOO heavy based on the pics. Please feel free to keep proofreading as well. I fixed the timing - not sure where the 10 degrees came from considering I drew the illustration with 12!
I think the way I had the '68 emissions stickers done with the glossy UV protective coating would work well for these.
The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
#128
Ken, I also agree with you on the '69 350,400, 428 4-bbl emissions decal to not be completed until we find an original.
Dennis |
#129
Just for reference, here's Dan's '69 350HO Firebird's original air cleaner (PV code 6485501) with the HD filter option.
Dennis |
The Following 2 Users Say Thank You to SD455DJ For This Useful Post: | ||
#130
Thanks for working on these Ken!
Will be in for half dozen '71 455 HO emission decals. Several '69 emission decals as well.
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
#131
If anyone has a high res photo of a 455 HO decal drop me a line. I'm having trouble figuring out the finer details of that one via the low res pics in the forum.
#132
Took a pass at refining the 455 HO label. As far as I can tell, some of the lines breaking up the info are thicker than others. I was bouncing between a couple different fonts for the tuning instructions, and I think I got it as close as I can. If someone has an original to compare to, happy to email a higher res version to print out. I also need a size for this label.
#133
Crude dimensions are here...
https://forums.maxperformanceinc.com...d.php?t=472074
So long, farewell. |
The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
#134
Looks like I'm not the first person to go down this path! The pics in that thread are helpful, thanks. It appears my assumption about the line weight in the decal was wrong. I can tackle the '72 decal once I get this one nailed.
#135
Dennis |
#136
I have one still on my car, if you would like a better picture I can get one next week sometime. It's not perfect but it might be good enough for some info. Just curious, have you tried a hand held inkjet printer to see how it compares to the silk screen? I work for a company that makes labels and signs and we had one here in the shop for a project a while back. It will print jpegs if I'm not mistaken. I'll have to see where that printer ended up. I know I was playing with it and it would do color company logos. |
#137
#138
Really looking good Ken!
Dennis |
#139
Got into the weeds on this one tonight. Thanks to Dennis for sending me a high res pic to work off of, it helped quite a bit. I ended up redrawing it at 4x the actual size to capture all the details and shrinking it down.
It turns out I had the wrong style periods (square vs. round) and I had to make a number of characters to match whatever the original font was. With the lower res pics, I was having a hard time figuring out what font weight the instruction list was. Much easier when I have a giant pic to work from. I had them too light in the previous iteration. I was also able to tweak the illustrations so they had a heavier line weight and matched the original exactly. Here's some of the process.... Draw on top of the pic of the original. It had a slight skew to it, but no big deal. Convert everything to outlines so I can tweak the fonts and get the inconsistent spacing down. Looking closely at the original, the fonts weren't super crisp. I could print them that way if folks prefer, but I also applied a slight rounding to all the fonts to mimic the sloppy original. Digital fonts are crisp and clean: Apply rounding to mimic the factory quality: The end result. Still needs a little bit of tweaking to fix up the letter spacing and some of my custom letters in some spots, but it's way closer than what I had and keeps some of that wonky factory charm.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) Last edited by Verdoro 68; 03-02-2023 at 02:46 AM. |
#140
I like the more rounded font ... but it's got to be pain to individually alter each letter. Hopefully you have some kind of font tool you use to do them en masse.
Thread Tools | |
Display Modes | |
