Old 07-16-2012, 09:02 AM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Talking exhaust manifolds for a yak 400 in a 78 GP
Swapping out a 301 for a 400. Need exhaust manifolds for the 400. Anyone got a set?
Thanks,
Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
Old 07-18-2012, 04:23 PM
Racer81x's Avatar
Racer81x Racer81x is offline
I should have some, do you want the 2 or 3 bolt flange style? 2 bolt is 60's-early/mid 70's 3 bolt mid 70's-late 70's
Old 07-18-2012, 04:48 PM
I guess which ever will bolt up to current exhaust.. I can find out if you dont know off the top of your head.
THANKS!!!!
Dave
The Burb Files
Old 07-18-2012, 06:00 PM
Racer81x's Avatar
THANKS!!!!
Dave
If factory it's probablly the 3 bolt, but you better check.
Old 07-18-2012, 10:21 PM
Groovy. Will do...
The Burb Files
Old 07-27-2012, 09:32 AM
Still waiting for the guy who owns the car to tell me 2 or 3..
The Burb Files
Old 08-07-2012, 04:46 PM
shotgun shotgun is offline
PY Staff -Tech
301 manifolds will bolt right up. They have an extra hole but the gasket covers that.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date 10.00@130.92 mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
Old 08-07-2012, 08:48 PM
Got a picture cause I heard they will not..
Thanks!!!
The Burb Files
Old 08-08-2012, 10:25 AM
PY Staff -Tech
No pictures but check around, I know a bit about the lowly 301. Also I ran non 301 logs on my 301 in the infamous T1000 with no issues, been there, done that.
Anyway , no exhaust is going to bolt right up to your existing exhaust using either 301 or standard (400) logs. This is due to the deck height difference between the 301 and the 400, the manifold sits approx. 3/4" higher and 3/4" further out.
Old 08-08-2012, 11:25 AM
Any way to fix that quickly? I am helping some one else and dont want this car here for a month!!
The Burb Files
Old 08-08-2012, 11:01 PM
Racer81x's Avatar
Here is a pic showing the difference between the 301 manifold and one for a 350/400:
The rusty manifold is the 301, the painted one is a 350/400
Old 08-09-2012, 01:23 PM
PY Staff -Tech
Depends, what exhaust is on it now, stock,duals etc.
Old 08-10-2012, 06:45 AM
Stock 301 manifolds. 3 bolt. In the future he is going to get the exhaust to true dual, but I lack the time and a lift to do it at the house.
The Burb Files
Old 08-13-2012, 11:07 AM
PY Staff -Tech
You may be able to wiggle the stock exhaust up into place but it will choke the motor.
Not what you want to hear but by the time something gets rigged up that time and effort would get you half way to a true set of duals.
Old 08-13-2012, 07:14 PM
Like 3 days after the engine is in, he has a family member that owns a exhaust shop They are gonna do true duals.
Starter??? Can I use the 301???
Thanks,
Dave
The Burb Files
Old 08-14-2012, 09:05 AM
PY Staff -Tech
The starter will work but it is a smaller lite duty unit. If the engine is mild it should last a while as long as the starter was in good shape to begin with.
If he plans on upgrading the engine (compression/cam etc.) in the future he will also need to upgrade the starter a that time.
Make sure the exhaust guy knows to leave room for a larger starter!!
Old 08-15-2012, 11:18 PM
WOW!! Great catch!!! I will make a note of that.
Thanks!!
Dave
The Burb Files
