Old 02-28-2018, 03:21 PM
woogie0004 woogie0004 is offline
Default lots of 70-81 trans am parts
please text or email me thefbodygarage7081@yahoo.com 8108754154 I do not log on to often so if you pm me it will delay a response. Located in Vassar Michigan but i can ship pretty well any part. Large parts will be shipping using fastenall. If you don't see what your looking for just ask Thank you, Adam
Rack 1 Shelf 1
71-74 seat cores 100.00
78-81 seat cores 100.00
Rack 1 Shelf 2
81 301 shaker set 300.00
79-80 301 shaker set up with hose 350.00
77-79 403 air cleaner 175.00 2 available
73-76 shaker set 350.00
Rack 1 Shelf 3
350-455 flywheel 75.00 3 available
350-455 flexplate 40.00 15 available
488296 water pump dated A052 25.00
80 amp alternator no #’s 50.00
Alternator newer 15.00 2 available
Alternator 110070 0c11 20.00
Alternator 1100704 8c6 60.00
Starter newer 15.00 2 available
70 ram air 3 exhaust manifolds 800.00
70 ram air 3 #12 heads 800.00
70 ram air 3 carb 7040270 1,200.00
Full length windage tray 75.00 3 available
¾ length windage tray 50.00 5 available
75-81 motor mounts 100.00 3 available
Rack 1 Shelf 4
Fuel pump 5.00
Fan spacer 5.00 4 available
Early style power steering dipstick 10.00 2 available
Throttle plate 20.00
Rear alternator bracket 40.00 6 available
77-79 throttle and kickdown bracket 30.00 2 available
Distributor hold down 10.00 11 available
Timing tab 20.00
Timing tab small balancer 15.00
Pushrod guide plate 10.00 3 available
Valve covers 50.00 2 pair available
Exhaust damper 20.00
Fuel eccentric 20.00 2 available
80 amp alternator bracket set with power steering brackets non adjustable 250.00
77-79 breather tube 20.00 2 available
Lower dipstick tube 15.00
Choke heat riser 40.00
Non ac dipstick tube 20.00
Crank pulley reinforcement 10.00 22 available
73-79 ac bracket set 200.00 3 available
Engine lift loop 10.00 2 available
Engine lift loop califonia emissions 15.00
71 only power steering brackets 80.00
72-79 power steering brackets 60.00 3 available
Thermostat housing 10.00 3 available
Positive wire loom 15.00 7 available
Angled oil filter adapter 40.00 22 available
73-79 exhaust manifold heat shield 20.00 4 available
68-72 standard exhaust manifold heat shield 20.00
Starter heat shield 20.00 2 available
Oil drippers 60.00
Timing chain cover 75.00 4 available
80 amp alternator aluminum bracket 30.00
Rack 1 Shelf 5
Oil pan 50.00 6 available
66 valley pan 75.00
Egr valley pan 100.00 5 available
Non egr valley pan 50.00 4 available
Valley pan gasket 10.00 2 available
Hei distributor 20.00
Rack 1 Shelf 6
301 turbo intake 40.00
301 turbo valley pan 40.00
301 turbo harmonic balancer 40.00 2 available
301 turbo coolant line 20.00
301 turbo exhaust manifolds 300.00 2 available
301 turbo breather tube 20.00
301 turbo distributor hold down 10.00
301 turbo exhaust pipe 40.00
301 turbo distributor 30.00
301 turbo ac lines 100.00
301 turbo turbo and plenum 200.00
301 turbo hood lights 350.00
301 turbo 1981 carb 250.00
301 turbo smog pump 50.00
301 turbo ecu 200.00
301 turbo heat shield set 200.00
301 turbo ac brackets 100.00
301 turbo alternator brackets 60.00 2 available
301 turbo power steering brackets 60.00 2 available
301 turbo 81 pulley set 100.00
301 turbo 80 pulley set 100.00
Rack 1 Shelf 7
Clutch fan 30.00 7 available
6x-8 heads 100.00
48 heads bare 100.00
6x-4 heads 200.00
Exhaust manifolds 9796992 h240 480602 h190 200.00
Exhaust manifolds 9779328 9779032 150.00
Rack 2 Shelf 1
Black 70 TA seat covers 200.00
81 recaro seat set NICE 3,500.00
81 pace car door panels NICE 400.00
Rack 2 Shelf 2
301 turbo air cleaner 150.00
73-76 shaker 125.00
Air intake air cleaner adapter 35.00 3 available
Air intake elbow 35.00 2 available
Air intake lower tube 20.00 3 avainale
Air intake elbow for 301 20.00
Rack 2 Shelf 3
72-81 4 speed pedals 75.00 4 available
70-71 4 speed pedals 100.00
BOP bellhousing 150.00 3 available
4 speed shifter mount 20.00 2 available
Z bar 50.00 2 available
Ball stud 10.00 2 available
fork 20.00
4 speed tunnel 30.00
4 speed console bezel 20.00
70-74 4 speed crossmember 100.00 2 available
75-81 crossmember 50.00 5 available
Rack 2 Shelf 4
Automatic transmission dipstick tube 15.00 3 available
Catalytic converter bracket 50.00 12 available
81 only catalytic converter bracket 100.00
Th350 saginaw muncie drive shaft yoke 20.00 6 available
301 turbo kick down cable 40.00
New U bolts 15.00
Inspection cover for auto 30.00 3 available
Auto reverse lock out 70.00 7 available
Auto reverse lock out cup 20.00
Shifter bracket 20.00 5 available
Th350 cable bracket 20.00 10 available
Th400 cable bracket 30.00
Limited slip tag 5.00
Th400 yoke bolt on style 40.00
Rack 2 Shelf 5
Pulleys
481039 xf 40.00 5 available
9799127 xf 40.00 2 available
10004850 yy 30.00 6 available
481040 xt 40 5 available
481042 xd 40.00 3 available
493243 40.00 2 available
496411 yp 40.00 6 available
9786900 xd 40.00
481038 yb 40.00 10 available
480507 xk 60.00
9790842 yb 40.00
486005 xb 40.00
480509 20.00 14 available
Rack 2 Shelf 6
Olds 403 intake 150.00
496140 intake dated H234 50.00
9794284 intake dated J030 150.00
525355 intake dated D026 50.00
481733 intake dated O100 150.00
Carb 17057262 80.00
Rack 2 Shelf 7
400 block yt f194 4819888 350.00
400 block ya h167 500557 250.00
400 block yx E302 481988 350.00
400 block vt L064 488988 350.00
Rack 3 Shelf 1
78-81 black cloth front bucket seats 100.00
Rack 3 Shelf 2
73 grills 125.00
70-73 master cylinder with bleeders 20.00 4 available no codes visible
70 master cylinder with proportioning valve and bracket 40.00 no codes visible
70-71 door hinges 60.00/set 2 available
70-73 fender valance brackets 200.00/ pair 2 available
70-73 fender valance bracket driver side 100.00
70-72 core support middle brace 100.00 4 available
71 firebird fender grills and cut outs 100.00/pair 2 available
Rack 3 Shelf 3
70-73 middle rearned bump stop 30.00 5 available
70-71 console seat belt clips 20.00
70-71 wiper switch 20.00
70-73 fuel door 30.00
73 seat belt headliner holders 100.00
70-71 door panel brackets 100.00/set of 4 7 available
70 only rearend bump stops 150.00/pair 3 pair available
71-73 rear end bump stops 100.00/pair
70-73 tail panel valance 100.00 needs work
70-73 front spoiler NOS? 450.00
70-73 front license plate holder 30.00
Headliner bow set with ends 100.00 3 available
70-72 parking lamps complete set up 150.00
70 only black visors 150.00
70-73 horns 80.00/pair 2 available
70-71 trans am dash bezel non ac 500.00
70-71 trans am dash bezel ac 500.00
70-71 firebird dash bezel with gauges and ac 250.00 3 available
70-71 firebird dash bezel with ac no gauges 60.00
70-71 firebird dash bezel with no gauges no ac 100.00
Rack 3 Shelf 4
70-73 spoiler ends 150.00
70-73 parking lamp grills 20.00/pair 2 available
Manual brake rod 20.00
73 grill brackets 60.00/pair 2 available
70-73 throttle cable 40.00
70-73 taillights 100.00
70-73 headlight rings 10.00 5 available
70-early 73 headliner side trim 100.00/pair 3 available
70 only glove box door 100.00
70-74 motor mount bolts 10.00/pair 2 available
73 parking lamps 60.00/pair
70-71 backing plates 50.00
70-73 large frame L brackets 200.00/pair 3 available
70-72 small L brackets 50.00/pair 3 available
Rack 3 Shelf 5
Complete 73 firebird bumper 700.00
Rear window trim 75.00
a/c condenser 40.00 3 available
Rack 3 Shelf 6
Space saving spare tire 100.00 2 available
70-73 ac suitcase 125.00 2 available
Spare tire inflator 80.0
Rack 4 Shelf 1
78-81 red cloth bucket seats 100.00
Rack 4 shelf 2
75-81 sail panels 100.00/pair 8 available
75-81 sail panel passenger side 50.00 2 available
72-81 rear arm rest 100.00/pair 5 available
72-81 rear armrest driver side 50.00 2 available
Rack 4 Shelf 3
Steering column cover 50.00 15 available
Glove box door 50.00 8 available
Cigarette lighter 10.00 9 available
80-81 front speaker grills 30.00 4 available
Seat hinge cover 30.00/pair 4 available
Visors 30.00 each 45 available
Visor brackets 10.00 each 27 available
T top small trim pieces 25.00 each 18 available
Seat belt covers 50.00/pair 15 available
Dash prism 15.00 15 available
Rack 4 shelf 4
Ac kick panels 80.00/pair 3 available
Non ac kick panels 80.00
Seat backs 30.00 each 11 available
Rack 4 Shelf 5
77-81 ac suitcase 100.00 3 available
75-81 rear glass 50.00 6 available
Rack 5 Shelf 1
78-81 camaro seat cores 100.00
Rack 5 Shelf 2
79-81 tan dash cut radio hole 500.00
Non tilt 70-78 steering column 75.00
Tilt 70-78 steering column 200.00 2 available
Non tilt 79-81 steering column 75.00
Column bracket 15.00 4 available
Rack 5 Shelf 3
70-71 speedo 60.00
77-79 6k 100 mph speedo gauge cluster 150.00
81 6k 100 mph speedo gauge cluster 150.00
8k 100 mph speedo cluster 200.00 2 available
8k 160 mph gauge cluster 74-76 250.00
8k 160 mph gauge cluster 350.00 has 72 and up tach
100 mph gold line speedo 30.00 2 available
Pace car gauge set 350.00 2 available
Pace car ac controls 100.00 2 available
10th anniversary gauge cluster 350.00
Glove box literature 20.00 each 15 available
80-81 volts fuel gauge 25.00 5 available
75-79 volte fuel gauge 25.00 13 available
71-74 volts fuel gauge 100.00 4 available
70 volts fuel gauge 100.00 5 available
70-71 firebird ac controls 100.00 2 available
72-76 firebird ac controls 100.00 2 available
72-76 trans am ac controls 100.00 3 available
70-76 heater control bracket 10.00 8 available
Intermediate wiper switch 50.00 4 available
Standard wiper switch 10.00 4 available
Headlight switch 10.00 5 available
77-81 ac control cable 15.00 7 available
70-76 ac control cable 25.00
77-81 non ac heater control cables 75.00 4 available
Rack 5 Shelf 4
78-81 arm rest 50.00 each 18 available
Power door plugs 30.00/pair
Hurst plastic trim 100.00
Arm rest inserts 5.00 26 available
75-81 clothes hanger hooks 5.00 each 36 available
70-74 clothes hanger hooks 5.00 each 9 available
Horn contact button 10.00 3 available
Radio knobs 15.00
Horn cap 30.00 2 available
Speaker bracket 15.00 3 available
Shifter knob automatic 30.00 8 available
Shifter center button 15.00 2 available
70-71 am fm radio 275.00
Fischer t top clips 5.00 each 110 available
Dash bezel bird 10.00
Seat belt triangles 10.00 each 12 available
Map pocket 30.00 9 available
Dash bezel rings 5.00 each 48 available
Lighter nut 5.00 11 available
80-81 computer door console clip 60.00
Radio bracket 10.00 7 available
70-77 door pulls new 50.00/pair
77-79 non ac heater controls 75.00 7 available
77-79 ac controls 75.00 4 available
80-81 non ac controls 75.00 2 available
77-81 rear defrost switch nice 40.00 5 available
70-76 power door lock switch 100.00 6 available
Dash plates where switches go 10.00 11 available
70-71 firebird dash plate 30.00
Dome light lens 10.00
Rack 5 shelf 5
Hood hinges 60.00/pair 8 available
72-77 upper door panels 100.00/pair 2 available
Rack 5 Shelf 6
Side glass 20.00 each 18 available
Rack 6 Shelf 1
74-78 tail light wiring 30.00 4 available
Intermediate wiring 20.00 2 available
Cruise control wiring 20.00
70-72 headlight wiring 50.00
81 ecu wiring 50.00
Ac wiring 77-78 30.00 2 available
Rear defrost wire 20.00 2 available
77-81 power window and lock wiring 80.00 5 available
Dome light wiring 20.00
Shifter light wiring 10.00 3 available
79-81 ac wiring 30.00 2 available
77-78 headlight engine bay wiring 50.00
Cruise control set up 100.00 2 available
Fuel sending unit 10.00
Decklid courtesy light 20.00 4 available
81 301 turbo engine bay wiring 50.00
Power window switch wiring 20.00 2 available
Ashtray wiring 10.00
70-73 ac wiring 40.00 2 available
77 interior wiring 75.00
77 engine bay headlight wiring 50.00
Non ac wiring 20.00 3 available
Dah courtesy light wiring 20.00
Rear speaker wiring 20.00
70-73 tail light wiring 40.00
70-76 power lock wiring with switch and actuators 500.00 2 available
79 ta cruise control wiring and cables 40.00
78 complete harness 150.00
77 complete harness 150.00
79-81 tail light wiring 20.00 8 available
Rack 6 Shelf 2
Behind radio ac duct 75.00 5 available
Crothe vent driver side duct 75.00 15 available
Hush panel 40.00 12 available
Dash brace 10.00 10 available
Rack 6 Shelf 3
78-81 deluxe seat belts 200.00 4 available
78-81 standard seat belts 200.00 7 available
76-77 standard seat belts 200.00
72 seat belts 500.00
70 seat belts 500.00
Rack 6 Shelf 4
Ashtray 20.00 8 available
Steering wheel hub 25.00 15 available
Rear speaker grill 30.00 each 6 available
Headliner side trim 100.00/pair 3 available
Bump shifter 80.00 2 available
Shifter 50.00
72-77 door panel brackets 10.00 23 available
Center console box with lid 75.00 2 available
Dash ac vents 30.00 6 available
Horn contact 15.00 3 available
Dash bezel 60.00 7 available
Rack 6 Shelf 5
75-81 seat tracks 200.00 11 available
Rear seat bun trim 20.00 each 2 available
Seat track covers 5.00 each 28 available
Carpet protector 10.00 4 available
Rack 6 Shelf 6
A pillars 20.00 9 available
Door boots 15.00 each 5 available
Radio cut out 20.00
72-77 lower door panels 150.00/ pair
72-77 lower door panel passenger side 75.00
Power window motors 60.00/pair
Rack 6 Shelf 7
Center console 30.00 2 available
Non ac boxes 100.00/pair 2 available
Non ac engine bay box 25.00 3 available
Rack 7 Shelf 1
78-81 camaro rear bumper 60.00 3 available
77-78 rear bumper 80.00
79-81 rear bumper 50.00 3 available
76 front bumper 300.00
Rack 7 Shelf 2
Non ac duct set of 5 100.00 2 available
Non ac defrost duct 30.00 2 available
Ac defrost duct 30.00 5 available
Passenger side main ac duct 75.00
All other ducts 10.00 each
Rack 7 Shelf 3
Black 78-81 door panels 100.00
Red 78-81 door panels 40.00
Rack 7 Shelf 4
Fischer t top bags 50.00 each 11 available
Jamb vents 10.00 each 6 available
77-81 eyebrow trim 20.00/pair 2 available
71-76 eyebrow trim 20.00/pair
Door cups 15.00/pair
Door cups new 25.00/ pair
77-81 power window switch 20.00 5 available
70-76 power window switch 20.00
77-81 power lock switch 15.00 each 5 available
Fischer t top handles 35.00/pair 2 pair available
Door panel trim 50.00/pair 2 available
Remote mirror bezel 10.00 22 available
Hood trim 50.00
Rear armrest ashtray 25.00/pair
Window cranks 10.00 each 17 available
Shaker ring 30.00 3 available
T top latches 25.00/set 11 available
Door lock knobs 5.00/pair 5 available
Rally rim caps 60.00
Dome light 15.00
Fender tip chrome 20.00/pair 2 available
Rack 7 Shelf 5
Black 70-78 dash 700.00
70-74 rear glass 50.00 7 available
74-76 ac suitcase 100.00
Rack 7 Shelf 6
301 turbo ac suitcase 100.00
Driver side half of ac suitcase 60.00
Inflator bottle 40.00 2 available
Rack 8 Shelf 1
77-81 core support 100.00
74-77 camaro core support 60.00
74-81 passenger side frame rail 150.00 2 available
74-81 driver side frame rail 150.00
Rack 8 Shelf 2
79-81 taillights 200.00 5 available
74-78 taillights 80.00 3 available
Rack 8 Shelf 3
Fender cut outs 75.00 2 available
77-81 core support center brace 20.00 5 available
Side mirrors 40.00 each 22 available
Side mirror bracket 5.00 each 32 available
Gas cap 10.00 13 available
Door handle 10.00 6 available
74-81 gas tank straps 10.00 each 6 available
Rack 8 Shelf 4
79-81 air dam 100.00 4 available
403 oil filter adapter 30.00 2 available
403 distributor hold down 10.00
403 power steering bracket 50.00 2 available
403 ac bracket set 300.00
403 alternator brackets 60.00 2 available
403 ac pulley set 100.00 2 available
403 throttle cable bracket 30.00
Gas pedal 15.00
301 alternator bracket 20.00
301 power steering bracket 20.00
301 ac brackets 60.00
Rack 8 Shelf 5
79-81 flares 40.00 each 19 available
70-78 flares 75.00 each 7 available
79-81 aftermarket 5 piece flare and air dam set 200.00
Rack 8 Shelf 6
74-78 spoiler ends 75.00/pair 4 available
Center spoiler 40.00 5 available
79-81 spoiler ends 75.00/pair 6 available
Rack 8 Shelf 7
Jack set 100.00 8 available
Cowl screen 10.00 5 available
Ac heater core housing 40.00 2 available
Rack 9 Shelf 1
77-78 front bumper support 50.00 2 available
77-81 core support 100.00 8 available
73-76 core support 100.00
70 only core support 100.00 2 available
Rack 9 Shelf 2
Wiper arms 25.00/pair 19 available
Windshield 60.00 2 available
Rack 9 Shelf 3
Rear sway bar brackets 10.00 each 14 available
Proportioning valve bracket 10.00
Front sway bar brackets 15.00/pair
74-81 rear sway bar drop links 40.00/pair 5 available
77-81 headlight trim 10.00 each 14 available
77-81 headlight buckets 40.00/set 4 available
Marker light bezels 5.00 each 28 available
70-76 drip rails 150.00/pair 2 available
Marker lights 15.00 10 available
Door seal hold ins 40.00/pair 2 available
T top door seal hold ins 40.00/pair 3 available
Rack 9 Shelf 4
Rear End plates 20.00/pair 5 available
New KYB shocks 40.00
Exhaust hangers 10.00 each 5 available
Trunk popper button 15.00 2 available
Tail Light harness cover 5.00 each 3 available
J rods 5.00 5 available
Door plugs 5.00 14 available
Windshield stops 5.00 7 available
77-81 front license plate bracket 30.00 2 available
79-81 core support to bumper brackets 40.00
Wiper transmission 20.00 4 available
Throttle cable 15.00 3 available
W72 subframe braces 25.00 each 7 available
Trunk popper solenoid and button 75.00
77-81 inner fender splash guards 50.00/pair 5 available
Radiator bumps 4 for 5.00 26 available
Non ac heater core brackets 15.00 5 available
77-78 hood latch with cable bracket 50.00 4 available
79-81 hood latch with cable bracket 50.00 2 available
Hood latch 20.00 9 available
Rear leaf spring bracket 15.00
Nos 77-81 hood latch cable 40.00
79-81 hood latch cable bracket 35.00 3 available
77-78 hood latch cable bracket 35.00
Hood spring 10.00 8 available
Leaf spring pockets 40.00/pair 2 available
Rack 9 Shelf 5
Trunk latch 10.00 3 available
79-81 rear bumper side brackets 20.00/pair
Hard ac lines 15.00 each 6 available
79-81 headlight bezels 50.00 2 available
Gear box covers 20.00 5 available
Inner fender brackets 20.00/pair 3 available
74-78 license plate bracket 30.00 2 available
77-81 front bumper brackets 30.00
Radiator hold ins 5.00 each 7 available
Core support to fender brace 15.00 each 24 available
80-81 front speaker brackets 20.00/pair
Door latch 10.00 each 3 available
Parking brake 20.00 3 available
74-81 horns 25.00 17 available
Rack 9 Shelf 6
B pillar trim 10.00 8 available
Rear sway bar 50.00 5 available
Front sway bar 50.00
Brake pedal 20.00 2 available
Brakr pedal 4 wheel disc brake 60.00
Speedo cable 10.00 8 available
Rack 9 Shelf 7
Th350 drive shaft 60.00 5 available
Ac lines 60.00 3 available
Filler panel 30.00 5 available
Trunk torsion rods 40.00/pair 6 available
79-81 intermediate shaft 40.00 2 available
70-78 intermediate shaft 40.00
Under sill plate wire covers 50.00/pair 7 available
Rack 10 Shelf 1
74-78 gas tank 40.00
Headliner board 40.00 2 available
Fischer t top roof 100.00
Rack 10 Shelf 2
Appliance style rims 150.00/set
Turbo rims 300.00/set
Rack 10 shelf 3
8” snowflake rims 300.00/set
7” snowflake rims 150.00/set
78-79 z28 rims 100/pair
N90 80-81 z28 rims 150.00/set 3 available
Rack 10 Shelf 4
7” snowflake ims 150.00/set 2 available
American racing rims 200.00/set
8” snowflake rimes 150.00/pair
14” honeycomb rims 120/set
Rack 10 Shelf 5
Camaro door passenger side 100.00 2 available
Trans am door driver side 100.00
Rack 11 Shelf 1
Door hinges 10.00 each 16 available
Washer jug 10.00 6 available
Coolant jug 15.00 5 available
Wiper motors 10.00 7 available
Door tracks 40.00 a set
Rack 11 shelf 2
Upper control arms 30.00/pair 2 available
Non power steering gear box 100.00
74-81 new RH frame rail back half 100.00
77-81 headlights with buckets and trim 50.00/set
Rack 11 Shelf 3
Leaf springs 100.00/pair 3 pair available
Power window regulators 60.00/pair
Rear sway bar with drop links 60.00
Rack 11 Shelf 4
Ac compressor 40.00 12 available
68-70 power steering pumps 15.00 2 available
Rack 12 Shelf 1
77-78 rear bumper 80.00 2 available
Rack 12 Shelf 2
Decklid 60.00 7 available
Rack 12 Shelf 3
New subframe connectors 80.00
New rockers 50.00 each 3 available
403 fan shroud 100.00
Center spoiler missing studs 20.00
Rack 12 Shelf 4
76 trans am front bumper brackets 100.00
74-75 front bumper brackets 100.00/set 2 sets available
77-78 front bumper 80.00
Rack 12 Shelf 5
Newer gray carpet 40.00
79-81 rear bumper 50.00 2 available
Rack 12 Shelf 6
Brake booster 20.00 3 available
70-72 nose 100.00 needs work
Rack 13 Shelf 1
New LH torque box 50.00
New rear inner quarter 35.00 2 available
New 74-77 camaro tail panel 40.00
Rack 13 Shelf 2
Small block chevy flywheel 20.00 2 available
Small block chevy bellhousing 100.00
Camaro inner fender brackets 20.00/pair
Chevy inspection cover 20.00
Camaro shifter knob 20.00
Camaro coolant jug 10.00 2 available
Camaro glove box door 20.00
Camaro steering wheel center cap 20.00
Camaro washer jug 10.00 2 available
Camaro 78-81 headlight bezels 20.00/pair
Camaro 78-81 parking lamps 20.00/pair 2 available
Camaro 79-81 dash bezel 20.00 2 available
Rack 13 Shelf 3
Camaro 74-77 header panel 80.00
Camaro 74-77 parking lamps 15.00/pair
Camaro 74-77 fuel door 20.00
Camaro 74-77 upper grill 20.00
Camaro 74-77 front bumper brackets 40.00
Camaro 74-77 headlight bezels 20.00/pair
Rack 13 Shelf 4
BOP th350 short tail 60.00 3 available
BOP th400 long tail 120.00
200r4 100.00
Rack 13 Shelf 5
BOP th400 short tail 120.00
Chevy th350 long tail 100.00
Muncie m20 4 speed 600.00 2 available
Rack 14 Shelf 1
Camaro 4 speed console 100.00 2 available
Camaro auto console 30.00
Rack 14 shelf 2
Camaro 74-81 spoiler ends 50.00/pair 5 available
Camaro 79-81 non tilt column 50.00
Camaro 78-81 taillights 20.00 each 8 available
Rack 14 Shelf 3
Camaro 70 only lower dash 225.00
Camaro 70-78 non ac dash 150.00 2 available
Camaro 70-73 ac controls 100.00
Camaro 78-81 bumper straps 60.00/pair 2 available
Camaro 70-78 dash bezel 125.00
Camaro LH under dash vent 60.00
Camaro 78-81 z28 rear flares 40.00 each 3 available
Camaro z28 subframe braces 40.00
Rack 14 Shelf 4
Camaro 79-81 dash 200.00
Camaro lighter 5.00 4 available
Camaro fender chrome trim tips 15.00/pair
Camaro 70-71 am fm radio 100.00
Camaro km/hour cluster 200.00
Camaro tach cluster no broken tabs 250.00 2 available
Rack 14 Shelf 5
Camaro hood latch 20.00 2 available
Camaro 74-77 taillights 20.00
Camaro fender to core support braces 10.00/pair 3 available
Camaro 70-73 gas tank 30.00
Rack 14 Shelf 6
Camaro 78-81 rear bumper 60.00 2 available
Non ac wiring
Other
Camaro new door skin 40.00
Camaro new 74-77 quarter panels 50.00 2 available
Camaro z28 passenger side fender 100.00
Trans am fender need work 100.00 each 2 available
Trans am fender needs minor work 150.00 each 2 available
77-78 trans am nose 200.00 2 available
Inner interior quarter panels 50.00 each 2 available
Camaro inner fender 50.00 3 available
Trans am inner fender 30.00 each 6 available
Trans am inner fender 70-72 50.00 each 4 available
78-81 camaro nose 150.00 3 available
79-81 trans am nose 150.00 2 available
241 posi rear end 100.00
Open rear end 100.00
Driver side quarter panel frame rail and tail panel 250.00
70-72 nose complete 900.00
78-79 z28 hood 100.00
80-81 z28 hood 100.00 3 available
77-81 formula hood 50.00
80-81 turbo hood 250.00
77-81 firebird hood 50.00
77-81 trans am hood 250.00
Front windshield trim 10.00 each 60 available
Rear window trim 10.00 each 60 available
Sill plates 10.00 3 available
77-81 drip rails 30.00 each 10 available
Driver side floor pan 40.00
Old 03-02-2018, 09:11 PM
lots of parts left
Old 03-06-2018, 05:43 PM
Old Goat Racer's Avatar
Would you have any radio knobs for a 78 TA
Everybody knows somthin.
Nobody knows everything !
Old 06-15-2018, 03:31 PM
unruhjonny's Avatar
Adam;
I sent you a text message on Sunday June 10th - I am wondering if you received it.
1970 Formula 400
Old 06-16-2018, 04:18 PM
robg8r's Avatar
robg8r robg8r is offline
sent email for spacesaver spare and jack set
Old 08-23-2018, 04:58 PM
unruhjonny's Avatar
I don't know how to post to maybe make others aware that I feel slightly burnt, and ignoring my text and PM seem to me at least to make it clear that you think it cool to ignore me.
I would hope that people might see that I have given you two months to reply... so it's not like I've been impatient.
1970 Formula 400
Old 06-03-2019, 06:19 PM
Dave73TA's Avatar
Dave73TA Dave73TA is offline
Hey Woogie I am looking for 73 AC parts . Under the hood , What do you have . I see you have the suit case .
Old 06-03-2019, 08:56 PM
steve v's Avatar
steve v steve v is offline
You may want to call, text or email him @ the #/email he gave in his ad. He hasn't been online here since Aug 2018.
Old 06-03-2019, 10:40 PM
78 TA KID's Avatar
78 TA KID 78 TA KID is offline
looking for 77 78 or 79 w72 carb.....
Old 06-12-2019, 08:25 PM
shakerz's Avatar
shakerz shakerz is offline
Has anyone bought parts from this member?
70 lucy auto t/a, 70 polar 4 speed no air t/a, 78 y82, 79 y84
Old 06-12-2019, 11:45 PM
beerslob beerslob is offline
hes a good seller
Old 06-13-2019, 09:16 AM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
I need a lower vapor canister bracket for a 74 Bird.
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
Old 06-13-2019, 11:21 AM
shakerz's Avatar
Originally Posted by beerslob View Post
hes a good seller
Old 10-23-2019, 08:10 PM
Any thick trunk torsion rods for spoiler cars available?
Old 03-23-2022, 04:46 AM
Dave73TA's Avatar
Default Bumper to frame washer
Would you have the conical washer that is used to bolt 73 front bumper to frame . With spline bolt ?
Old 03-23-2022, 10:08 AM
78w72 78w72 is offline
looks like he hasnt been active on here for 2.5 years... probably need to email or call him.
Old 03-23-2022, 11:15 AM
Dave73TA's Avatar
Figured it would pop up in his email.I think he s on Facebook sights .I figured it out .I think.I go to a sight teufert.And they have diagrams with part numbers .But 73 number usnt listed Went to 75 and it's listed Gm 492370.Googled it and ebay or amk bolts has them.
Old 03-27-2022, 09:57 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
Adam is SOLD OUT of f-body stuff
Just chatted with him....
